Calvin H-C
- First Name
- Calvin
- Dec 15, 2022
- Richmond Hill, Ontario, Canada
- Ford Focus Electric 2017, F150 Lightning Lariat
- Occupation
- Technical Trainer/Writer - Wayside Railway Signalling Maintenance
Just speculation for the most part, partly from something one may have read somewhere sometime.Many threads on this. There will be 16 responses with 21 answers, most of them worthless opinions...
Here's a bit more speculation on my part, but based on eight years and 176,000+ km of experience with a Ford Focus Electric...
Charging to 100%: with the FFE, that's one's only option, unless you manually unplug, or if charging is incomplete when the "value charging" window ends.
Given the average range in a full charge (160 km), the mileage on the vehicle, and the fact that the average charge would start at about 50%, that means my battery has likely endured at least 2500 charging cycles to 100%. I'm still getting pretty much the same range as when the car was new, so it doesn't appear charging to 100% is doing anything detrimental.
When one charges to 100%, the battery control module will perform cell balancing at the end. I suspect this is likely good for the long term health of the battery. Though we have the Lightning set to charge to 90% at home, we will have it go to 100% once per month or so for this reason.
Running to very low SOC: back in the days of NiCad batteries, there was a significance of "battery memory" where if one regularly ran down to say 50%, then after awhile, the battery would run out at that point instead of still having half its capacity remaining. I understand that lithium ion technologies have substantially, if not completely eliminated this effect, but I have a gut feeling that there may be a tiny effect still. I wouldn't recommend on planning to get that low, but occasionally breaking a personal rule like never running it down below 10% (or your personal minimum) shouldn't cause a problem, and may be beneficial.
DC Fast Charging: I've heard some say this causes life-shortening stress on the battery sounding like the way everything that crashes on The Simpsons bursts into flames.
Modern battery technology is designed to take it, but it strikes me that too much could be an issue. By the same token, I suspect it is good for the battery to occasionally get a high power kick in the ass. Use fast charging for road trips and the occasional emergency and do most of your charging on an AC EVSE.
I will note that the high power of DC Fast charging might have more of an effect on your battery's contactors than it's cells. All that power passing through them in the reverse direction. I just had to replace a contactor on one of my FFE battery packs (the FFE has two), and though I don't fast charge very often, and the fastest charge it's ever received was 53 kW, the thought of this on the contactors did cross my mind.
Despite all I've said above, don't forget that your mileage may vary.
