ECG-26.2.11.4.1 SW Update 12 - Central Computer
FYI, I believe this is EAP - you should have received an email about a month ago. I don't mind - just don't want to see anyone lose the privilege.
Sounds good...but...what could go wrong? :)
Tom M
Bossier City, LA
2022 F-150 Lightning Lariat, 2025 VW ID.Buzz
Pilot, Instructor
I got this update on my 2022 Lightning this afternoon (7/24/2026). It has a very similar title to an additional thread, but has a very different set of release notes.
Ford F-150 Lightning ECG-26.2.11.4.1 SW Update 12 - Central Computer IMG_8523
abcut973
Anthony
Denham Springs
2022 F150 Lightning Platinum, 2020 BMW X7 xDrive40i, 2019 Mercedes C300 cab
Same here. I was on a walmart parking lot a hour ago.
Restarted my truck and this popped up!
Ford F-150 Lightning ECG-26.2.11.4.1 SW Update 12 - Central Computer 20260724_174735
pjell
Minnesota
Me as well. And on the same day I took it to the dealership to look into module issues due to the lack of updates.
Typically you can fix this by just disconnecting the 12 v battery for 10 minutes.
mitchh
Mitch
2022 Lariat. old ice: Tundra, Outback, several old vws
Ditto, '22 Lariat
Still waiting....
Ford F-150 Lightning ECG-26.2.11.4.1 SW Update 12 - Central Computer point in tim
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
Is the ECG the same module as the GWM?
@Tom M @abcut973 @mitchh @02Reaper @pjell
I assume none of you are Early Access then? That means it’s rolling out to the general population. Starting with 2022s it appears.
As the notes indicate you will next receive a TCU and then a Sync update. That will complete the update to SU-12.
