Evans Rough Diesel Idle Sound Circuit
2023 Pro
I always thought that having an EV sound like an ICE vehicle was a cheesy idea. When I realized that the effeminate propulsion sounds (IMO) I have to put up with were mandated by Congress, I wanted to choose my own sound. I could not find an aftermarket diesel sound kit available yet. So, I bought this sound effects chip for a toy diesel truck as the basis of the project, which provides only the idling sound, not revving, which is enough for me and can be way loud enough to alert anyone. Instead of using MegaOhm I used an ordinary 4 ohm resistor to trick BCM into thinking its still hooked up to speaker, so no DTCs. Then I bought two 20W amp boards, IC soldered and stuffed everything in an electrical hobby box, got an extra AVAS propulsion sound speaker for the left side, a HVAC differential pressure switch (separate from vehicle electronics) set to 75pa connected to a 1/4" pitot tube at center of grille. 95 db legit Cummins idling diesel sound eminates from both sides/front of the truck. Cuts off at 30 mph when it can't be heard anyway. Other than sound chip and extra AVAS speaker from eBay, everything came from Amazon and was cheap. I know these sorts of things can be highly preferential. But, if anyone is interested, has questions, or wants parts list or pics lmk.
seajai
chris
Minnesota
2025 F150 Lightning Flash
Tile installer
Video of it working?
Jseis
Washington
The S.O. and I rented a Hertz Mach E GT with a Borla sound…system… It was hilarious as in big block rumble at the flip of switch plus very effective “shift“ sounds too! So loud that I’d turn it off when parking late in the eve at the hotel.
My ‘99 7.3 SD 250 was loud but not in a pleasant way. At full freeway boil it dominated conversation. Well, it do that on early morning startups & wake the dead too.
