✅ 10/02/2023 Lightning Build Week Group (MY2023)
Danface
Central Mass
2023 Lightning XLT
Not sure this is true but:
Ford F-150 Lightning ✅ 10/02/2023 Lightning Build Week Group (MY2023) 1704913525992
Apparently they do actually have the truck, heading there tomorrow afternoon to get the ball rolling. Maybe I should also buy a lottery ticket! :)
It's ABOUT DANG TIME!!!
Congrat's, your truck marks the last of Lightning production builds that I'm following!!
ctuan13
Chuck
Pittsburgh, PA
Well
@ctuan13 is an expert in Lightning cyber security, he may have some tips & risks.
I've personally never used FordPass, so I can't confirm precisely what does and doesn't disable its functionality, but from what I've seen, even the CANbus line being disconnected leads to setting a TCU code and from what I've seen from other's experiences any TCU codes set disables FordPass.
However, in theory there should be a way to block the personal data while still allowing FordPass functionality, unless a server authentication key is sent along with the data, in which case they probably can't be separated.
For me however, even if personal data is protected, my bigger concern is cybersecurity with regards to malware that could compromise the truck's system which can definitely still happen even if privacy is maintained.
So that's my personal reason for keeping the TCU disconnected, the privacy/data security is just an added benefit.
Danface
Central Mass
2023 Lightning XLT
Yeah, part of me want to just add my own wifi hotspot using an android and a 3rd party sim and circumvent Ford
Did you pick her up yet????
We need photos of the blessed event as the final Lightning I'm following, heck I should have driven up to Framingham myself to congratulate you!
Danface
Central Mass
2023 Lightning XLT
Not yet, it was damaged in transit ... Not sure of the extent and will be going there today to see it and do the paperwork. Final as in "forever" and feel free to drop around!
Unfortunately I have a packed day today, I hope the issue is minor and easy to fix!
Danface
Central Mass
2023 Lightning XLT
It's a small dent on the lower ridge on the passager door. Did all the paperwork and should pick it this week.
I'll take a picture of "the blessed event" and send it along!! :)
Ford F-150 Lightning ✅ 10/02/2023 Lightning Build Week Group (MY2023) IMG_20240113_110356
Pro or NO
Will
Pa
14 F150 ecoboost
Areospace machinist
Wow! I thought my luck was bad. Hope things go well for you from here on out. I'm still in the rough. Had to have mine flatbedded to the dealer on Friday.
