If you already have a spray-in, would you add a drop-in on top?
  • Yes
  • Maybe
  • No
Results are only viewable after voting.
3Wliners
Diamond Sponsor
Rachel
500 Kennedy Dr Sayreville, NJ 08872, USA
3wliners.com
Jeep Wrangler JLU
We’re seeing more builds running spray-in + drop-in together. And yeah, the first reaction is usually: “If I already paid for a spray-in, why add a drop-in—isn’t that wasting money?”
Short answer from a lot of real-world users: extra cushion, less rattle, better grip, and a sacrificial layer that keeps your spray-in from getting gouged when you chuck sharp or heavy stuff.
And we’ve been combing through pickup forums across models and the theme is consistent, check what they've said.
3Wliners
3Wliners
Diamond Sponsor
Rachel
3wliners.com
Jeep Wrangler JLU
So here's the conclusion:
  1. Spray-ins are great and look clean, but they’re not perfect.
  2. Stacking a drop-in on top can solve specific pain points (noise, slide, impact).
    Owners shared a ton of useful experiences—we figured it’s worth a proper poll here.
And...here comes our question:
• Yes — extra protection/grip is worth it
• Maybe — depends on price/fit/weight
• No — spray-in is enough
• Not sure — convince me in the comments
To make this useful and fun, we are hoping you can share your opinion down below this thread, and we are select one winner giving away 2 sets of bed mat to him/her or his/her friend from this forum
Here's the rule:
• Comment your take on spray-in + drop-in (real experience or what’s holding you back).
• @Tag one forum friend who’d have an opinion.
We’ll randomly pick one comment and send two bed mats — one to the commenter and one to the tagged friend.
• Multiple thoughtful comments = better odds, but one set max per person.
House rules
Keep it friendly, respect different setups, and skip the brand bashing. Real-world experience beats hot takes.
Dropping a few use-case screenshots below to spark ideas. Your pics welcome — especially that “one load that sold me” moment. Fire away 👇
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
I have a rubber mat on top of my spray in. Just to reduce sliding around of objects and protect the floor which takes most of the abuse. But when I hear "drop in" what my mind thinks of is those plastic bed liners that cover the floor and sides and bulkhead. There's no way I'd put one of those on top of my spray in.
I wonder if @chl uses a rubber mat already?
OK - it wasn't an option, but my preference is a bed mat to keep things from sliding around and nothing else. I have had spray in and drop in before, but they don't hold things in place nearly as well as a good rubber mat.
As for the sides, it is a truck. It is meant to get used and scratched. Since Ford went aluminum for the body, there is no risk of it rusting, so why worry!
The Weatherman
Dean
South Central KY
I also put a bed mat in over the factory spray in to preserve it and to reduce things sliding around. It works great for that purpose and adds a level of comfort for my knees when I need to crawl into the bed.
KingStraasha
Kevin
Dayton, OH
2023 F-150 Lightning Lariat ER, Antimatter Blue
For me, it would depend on the use cases. I don't tend to haul too many heavy things (e.g., Bikes, mulch in bags), so just the spray liner would be enough. If I found myself hauling heavier things that could gouge the spray liner, then I would add a bed rug.
Yep
Lytning
Georgia
I had a 2000 SVT Lightning with the OEM drop-in liner. I had the truck painted in 2017. There was a little scuffing on top of the bed floor ridges (seen on the 2 ridges on the left in the photo), but no wear through to bare metal. We decided not to repaint the bed, and reinstalled the drop-in bed liner.
snowy_91
James
Aurora, SD
2023 Lightning XLT SR, 2024 Blazer EV
I have a spray in with a rubber bed mat to keep things from sliding around.
Mike G
N. AL, USA
I said yes on the poll because I’d actually done that on my 2018 Raptor. In retrospect doing the Line-X and then putting a bed rug over that was indeed overkill. I traded my ‘18 Raptor for a ‘20 when the cam chain phasers started making noise and took the bed rug with me. I then sold the ‘20 Raptor back to my dealer, they really wanted it bad, but I kept the bed rug and put that in the ‘21 Powerboost I’d ordered when I sold back the Raptor. When my Lightning arrived I moved that bed rug over along with the hard tonneaux I’d bought for the Powerboost.
I take the bed rug out once a year and clean and wax the bed and then put everything back.
I don’t miss the spray in liner one bit and I’ll never get that again.
rdr854
Northern Virginia
My volunteer fire department, which averages approximately 4,000 calls per year, has not had any issues with the spray in bedliners despite their heavy use/abuse from hauling firefighting equipment and other bulky items and debris. The average life expectancy of our pickup trucks is 15 to 20 years. During the winter months, the pick up trucks have bed sanders so that they can respond on calls during snow storms.
ClevelandBeemer
2025 F150 Lightning Flash 131kWh
Bed mat on LineX Premium for me.
Brons2
Mij
Cybersecurity
I have the Ford bed mat, got it with points. I'd probably still use it even with a spray in as it has a nice texture that won't scratch up your knees if you're wearing shorts.
I had Line-X in one of my other trucks and it would scrape up your legs if you weren't careful.
GoodSam
Good
occupying space
currently using the full bed rug, walls covered, shaped around cleats, etc, works well for keeping things from sliding and okay for knees. Had a drop in on a 3/4 chevy but it can cover cleats and attachment points, and now with Pro Power Onboard, openings are needed for that as well. Just the thicker bottom bed rug, which I think is available, would be my choice. But if hauling rough heavy stuff regularly, the drop in, with an optional non-slip pad would be smart. Maybe a 70% coverage temporary drop in would be a nice accessory for my bed rug when bricks are to hauled?
FloridaMan655321
1973 F100, 2024 Flash
Last truck I had I included a spray in bed liner from the factory. I liked it a lot. Lightning didn't come with one so I bought kind of a combo of plastic on the sides with a somewhat thick rubber on the bottom. I figured I would see how I liked it and if it sucked I'd go back to a spray in bed liner.
With that said, I do appreciate a spray on bed liner from the factory and wish my truck had this. I also am fairly happy with my current setup. It's not perfect, but not horrible and was much cheaper. I don't see my current setup failing in any way, but if it did I would pay for a spray in bed liner.
I load kayaks in the back of my truck, and with my previous truck I just put down a piece of cardboard to keep it from scraping the kayak. That was the only real negative I had and it was super easy to fix.
