Almost to 36k final service
Early777
Earl
Vancouver
F150 lightning lariat
Frankly, I am not sure the service department has a clue. I keep getting texts to bring my lighting in for its oil change. I think the truck is purchased and some how we get entered into the great whirligig in the sky and these texts go out. I love my lightning tho. :)
Ekiehn
Eric
2023 F-150 Lightning Latiat, 2008 Ford Explorer, 2006 Ford Escape Hybrid
Little late commenting on this, but check your high beam headlights. My driver side high beam started flickering a few months ago. Some others in the forum also had this problem.. it was intermittent at first and hard to pin down which side was causing the problem but eventually for me got worse so it was easily identified. Since this has happened to others and seems to usually be the driver side headlight and because unless you use high beams you would never know you have a problem, be sure to check this out..
