Armrest/console lid padding is too thin.
3rd rock
Automotive Technician
Spent a little more time behind the wheel recently and my arm was beginning to get uncomfortable. So I fixed it with a cover, slips on and fits properly, doesn't look half bad either and it's fairly cheap.
Has just enough thickness to add without bulking up and creating a binding spot at the hinge and it's much more comfortable. Not exactly the same color but it passes my ocd test, must be getting old. :crazy:
Ford F-150 Lightning Armrest/console lid padding is too thin. 25lightningconsolelidcover
Ford F-150 Lightning Armrest/console lid padding is too thin. 25lightningconsolelidcover1
djryan13
DJ
Ford Lightning, Tesla MS
Like idea. Does it just slip on? Says it doesn’t work as flip down workstation though. Not a huge loss for me.
davel8257
Odon, Indiana
2024 F150 Lightning Flash, extended range battery
retired engineer
$31 bucks -- I'm in!
3rd rock
Yep just slide it on, has elastic straps on the underside.
bryce
Bryce
2023 Lightning Lariat ER, 1999 Boxster
Says it does not work on the workstation cover, but the two armrests appear the same size to me. Is the issue that it will not allow the workstation to unfold? That is ok with me as I do not use the workstation.
Can anyone attest to it fitting a workstation armrest? I could not find information about that on the listing.
ctuan13
Chuck
Pittsburgh, PA
The particular white box brand one I got two years ago, is no longer available, but this is identical to the one I've got that allows for full worksurface functionality in my Lariat:
https://amzn.to/49XPi6V
bryce
Bryce
3rd rock
DavidS
DAVID
Green Bay, WI
F150 Lightning Lariat
Finally put mine on and did a little testing. Works fine with a work table as long as you aren’t planning on using it, does indeed soften the elbow contact for road trips, and in the event my dog makes it past the barrier, seems like cheap insurance from permanent damage. Highly recommended!
3rd rock
Don't have that problem as my truck did not come with the workstation fold out. I Do have the fold down shifter though, seems odd to have one without the other.
