Can't Connect to a Tesla Wall Charger
JeffinPTC
Jeff
Peachtree City GA
25 Flash
I'm new to the party with a 25 Flash bought last week. I took the rebate instead of the Ford Charger because we already have a Tesla Wall Charger. We've never had an issue charging the Tesla, but a series of issues developed trying to charge the Flash.
1. The first time I tried to charge, I found out that the Ford supplied adapter is only for charging from the Tesla Superchargers and for some reason the truck will not draw power from it. Seems designed to sell more $100 adapters.
2. After buying a Lectron 48a adapter(yes the amp rating matter), it still would not charge. After 4 hours of multiple emails to Lectron and attempts to connect, the Lectron guy suggested:
Given the information we have so far, we suspect the Tesla Wall Connector is not enabled to charge a non-Tesla via an adapter.
There is a setting called compatibility mode specific to Tesla Wall Connectors Gen 3.
  1. Ensure Firmware Version: Verify that your Wall Connector is running firmware version 21.36.4 or later, as Compatibility Mode is supported from this version onward.
  2. Access the Tesla One App:
    • Open the Tesla One app on your device.
    • If you haven't already, connect your Wall Connector to the app by following the on-screen instructions.
  3. Navigate to Access Control Settings:
    • In the Tesla One app, select your Wall Connector.
    • Tap on 'Access Control' to view the available charging access options.
  4. Select Compatibility Mode:
    • Choose the 'Compatibility Mode' option.
    • This setting allows your Wall Connector to be compatible with older software versions and can help resolve charging issues with certain electric vehicles.
  5. Save and Exit:
    • Confirm your selection and exit the settings menu
He said "Tesla One" but that's the installer app. I found it on the "Tesla" app.
3. But I could not get to this menu. After the electrician installed the Wall Adapter 2 years ago, I plugged up the Model 3 and it just worked. No menu, no settings. And now I can't find the provisioning card. The QR code on the side of the Wall Charger must be Tesla proprietary because nothing happens when you point at it. So, remove the 4 T25 screws holding it on the mount and there is a Wifi network and PW to get to provisioning on your Tesla phone app. CB off is Best Practice before you open this, but the contacts inside are protected like a duplex outlet. Take a pix of the codes for the numerous times you'll have to do this, and for next time when you buy a new router.
4. I found my home network and put in the PW, and got the "Success!" But the app still said "no internet" or similar.
5. Work from home technogeek son gets involved and finds this:
The Tesla Wall connector will only work with WPA 2 security, not WPA3/ 2 that everything else in the house works with. Thx Elon. So, open up the router setup page, 192.168.0.1 for my TP-Link (PW may be admin, admin if you've never changed it, you should), find the Wireless Settings page, and change the drop down to WPA 2. Here's what my settings page looks like
Ford F-150 Lightning Can't Connect to a Tesla Wall Charger 1771502558847-5
Good Luck!
Jeff
yes, you'll quickly find that likely there is no 'problem' with the LIGHTNING, but the issues lie within TESLA's proprietary systems... just like APPLE protects their own... it's great and easy for a Tesla vehicle, but likely not for others...
- using the Lectron 'adapter' you mention is for the LIGHTNING to Supercharge Tesla DC Fast Charging at certain Tesla "Other EV" locations only, not for 'at-home' Level 2 charging from Tesla products.
- the other Level 2 adapter is probably the correct version, but it is an adapter only, not a work-around for a Tesla charger protocol issue...
most of us LIGHTNING owners use a typical NEMA 14-50 Outlet and plug in our Ford Mobile 30amp EVSE, or another third-party EVSE, and some others have hard-wired versions of the similar EVSE wall-mount units... none of these are specific to the LIGHTNING, and can charge any EV, even a Tesla...
JeffinPTC
Jeff
Peachtree City GA
25 Flash
The Lectron I bought says:
Lectron Tesla to J1772 EV Charging Adapter – NACS Converter, 48 Amp & 240V, Compatible with Tesla High Powered Connectors, Destination Chargers & Mobile Connectors for J1772 Electric Vehicles (Black)
https://www.amazon.com/dp/B09DCTJCTV?ref_=pe_125775000_1044873430_t_fed_asin_title&th=1
It doesn't specifically say "wall charger," but I think its implied with "Destination Charger."
Here's what the Lectron site says:
Ford F-150 Lightning Can't Connect to a Tesla Wall Charger 1771504605004-5f
https://ev-lectron.com/products/lec...tination-chargers-and-mobile-connectors-black
