Isn’t it generally not ideal to charge at 100%? I just charged a 100% last Sunday to test if i the truck can take a charge up to 100%(2 week old truck) and now the 100% charge that i wanted to happen did not go to 100% it stopped at 77% and had to plug in again to get 100%probably because you 'manually' started a charge, which bypasses any 'setting' you have... is 100% 'not' good?
That's why you got 100%manually start the charging
It's a little bit of a learning curve with departure settings and charging locations.Isn’t it generally not ideal to charge at 100%? I just charged a 100% last Sunday to test if i the truck can take a charge up to 100%(2 week old truck) and now the 100% charge that i wanted to happen did not go to 100% it stopped at 77% and had to plug in again to get 100%
Your data would be interesting. Do you have CarScanner and if so can you post mileage and HVB SOH for each EV? Not a lot of 100K vehicles. Or was the 100K for both combined?My two Ford EV’s now have accumulated 110,000 miles and I have noticed no deterioration.
Yes, sometimes mine decides I don't need a departure initiation. Just skips it, then next week it works, go figure...That's why you got 100%
Keep searching the forums for more info on how to use the settings.
Updates will occasionally stop the departure times and also January 1st it resets and won't go.Yes, sometimes mine decides I don't need a departure initiation. Just skips it, then next week it works, go figure...
