Status
Not open for further replies.
20ecoboost21
South Carolina
2021 F150 tremor
all i see is your GWM update as well. however, once updated, other updates will likely show up
Any tips on how to get past the GWM update. I go through the update process and even the USB update says complete on my radio screen but never clears on Fords side.
christophers
Christopher
Austin, TX
2021 F150 Platinum Hybrid
are you leaving the laptop connected and in the update mode while it does this?
FDRS will ask "was the update completed?" but don't click yes until the truck says complete. once that happens, FDRS will have you turn the truck off, on, and then validate the modules, then send the data to Ford that says its' good to go.
if you don't do those steps, then it will take a bit for your module information to make it back to the mothership.
20ecoboost21
South Carolina
2021 F150 tremor
Yea I've done this step by step a couple times and doesn't ever clear for some reason.
Ajzride
Alan
Houston
Eng
if I had understood the details of how this all works earlier, I would have recorded all the module information between every step made a map of what all the numbers progressed to along the way. My guess is you have a strategy number stuck in limbo.
if there is someone in the Houston area that has not updated yet and is wanting to use FDRS to do so, I can offer up my mongoose and FDRS license and support so we can step through it and gather that information.
Jesse-Infotainment
Jesse
Dallas
2024 F150 Lightning Platinum
What I see the files should be
188 - ML3T-14C206-DAC
124 - ML3T-14C088-DAB
If anyone can check that has a Job 1 that has fully updated their XLT 8" cluster where the APIM is at level 22034 what their cluster software shows. Or you can send me your vin and I can see
RellIk&5
Wayne
Las Vegas, NV
2021 F150 XLT Black Widow
My F188 is MU5T-14G676-EG
F124 is MU5T-14G677-ABA
VIN is 1FTFW1E86MKD74376
TJSparky
WA
2021 F150 XLT (302A) RockyRidge K2
Mine is the same as Relllk&5.
We both are at 21281 APIM
Both of us are XLT, 8” cluster, non 360 camera, non Blue Cruise.
Jesse-Infotainment
Jesse
Dallas
Yeah.. I’ll need to confirm with someone that is actually beyond that what their cluster version is. Once we do that we can know what you two have to do. Could be an issue with the 8” similar to the 12”
since both of you are in the same boat it makes sense
antho
Anthony
Houston, Texas
2021 801A Raptor
@20ecoboost21
I was digging into the datalog on mine and found below. Not sure if it has anything to do with the GWM hanging but in the GWM update data log it mentions the CMR and IPMA need an update. I havenet received and updates on those modules. So it could be hanging because of that.
Number of GIVIS warnings = 3
Node address = 7C1
Warning code = 152
Source = GVMS
Details = Assembly ML3T-3G590-AJ has update available in Has-Actions ACT0037849 with coordination flag set with no applicable CAGs applying to vehicle
Node address = 761
Warning code = 157
Source = GVMS
Details = Default Service Action Id SRV0002451 not available in service action list for Vin: 1FTFW1RG1MFXXXXXX
Node address = 706
Warning code = 152
Source = GVMS
Details = Assembly ML3T-14G647-FS has update available in Has-Actions RASG0002324 with coordination flag set with no applicable CAGs applying to vehicle
remtiwk
Central PA
F150
ok I think you and I are in the same boat. Same model and trim levels. I think the higher trim models are getting more updates for Sync than we are.
I have a Lariat with 360 camera but no bluecruise and I’m also at 21281. I was getting regular updates before, but nothing since that one.
Sbdavis1
Stephen
Fayetteville
2010 F150 Lariat ordered 2021 F150 Lariat
Financial Planner, Lawyer
I have a Lariat with 360 and Blue Cruise. Still waiting on that end. I’m at 21281 rev 244. Anyone able to see if I have any updates available?
Weighing whether I’m going to spring for the whole kit (Mongoose, license and battery maintainer).
I also am trying to figure out if I want to roll back Forscan from double honk, glare free, temp gauges, and cameras in motion.
1FTFW1ED0MFA93986
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
Lol
I remember when the majority of us had a similar list.
If I knew then what I know now it would be far less of an adventure and more of just an arduous task.
However, I gotta admit that something inside of me is now disappointed when I login and run a query only to find there's nothing there for my truck.
At some point you have to come down from the high? ?
Jesse-Infotainment
Jesse
Dallas
@20ecoboost21
Node address = 7C1
Warning code = 152
Source = GVMS
Node address = 761
Warning code = 157
Source = GVMS
Node address = 706
Warning code = 152
Source = GVMS
I dont believe the raptor will be receiving those updates. Ford stated the BC wont be available for Raptors
Status
