Dump bed possible on Lightning?
MountainAlive
Massachusetts, USA
I saw this FB Marketplace listing for a Ford truck that has a hydraulic bed that can dump. I’ve never seen this before. So of course it had me wondering if this could ever be done on a Lightning?
Ford F-150 Lightning Dump bed possible on Lightning? IMG_5225
I suspect there is not enough space for the ram and supporting hydraulic pump, etc.
MountainAlive
MountainAlive
Massachusetts, USA
My dad had an old/new 73 Ford truck with a dump bed installed on it. This was back in 74 or75.
If the hydraulics have room to articulate, I see no other reason it won't work on our trucks. It was a pretty simple system iirc.
That’s cool. I’ve never seen one of these in real life before but it seems like a really cool feature for not a lot of complexity.
mq019
2023 F150 Lightning Lariat ER
I mean, with enough money, ANYTHING is possible, but with the official payload capacity of these trucks so low already, the hardware to make it a dump bed would probably exceed or eat up the available capacity, so you'd have a dump bed that you couldn't put anything in - the one you showed was on a F350 for a reason!
Think about where some of the battery modules sit and maybe that would present some problems?
Ford F-150 Lightning Dump bed possible on Lightning? 9 battery modules
Robocop
2022 Platinum; 1962 Lincoln Continental
I think I recall reading somewhere that Ford does not recommend removing the bed and it has something to do with the HV battery and maybe the wiring.
Aminorjourney
Nikki
Internet
www.transportevolved.com
Given that there are outfitters out there who have developed rear beds for the lightning - I don't see why they couldn't re-engineer it to add tipper support.
The issue however is that you'd not only need to add space for a hydraulic or electric actuator - but you'd need to ensure it sits proud of the bed and the battery pack. The result would likely be a higher bed floor, and loss of bed depth.
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
Well I've had Ford Tractors before...but not like that !! :crackup:
