Enabling charge speed on dash.
Jesse-Infotainment
Jesse
2024 F150 Lightning Platinum
I understand how it is.. When I was first starting out with all of this.. I cant tell you how many APIMs I messed up.. IPMAs I was tinkering with loading 1.2 when it wasnt out for us yet.
Great thing about these modules is you really REALLY have to do something to make them not flash again.
IT happened to several guys in the iCE forum with the IPMA flash.. Those were 23 hours.. and it would fail for dead battery or whatever. They came running to the forum My IPMA is PURPLE NOW>.
I had to make a big post telling people what to do because it was happening so much
Some modules wont allow reflashing until you let the truck go completely to sleep. SO You have to do the hardest thing possible and leave it alone for about 30 mins. Lock the truck and walk away.
With The IPC though you can jump back in and get it running again.
Hope you got it all done.
astrand1
Alex
Studio truck driver
Cool Cool. Thanks. That makes me a *lot* happier ;). It's currently not raining, but it's looking like it might, and if this is going to take 6 hours... I'd like the cab to stay dry if it rains!
Good luck! Mine took about 5 hrs 20min. I also took the opportunity to get a temp license for fdrs and do those updates as well.
Aminorjourney
Nikki
Internet
www.transportevolved.com
What adapter did you use? I'm using one that's not known for playing nice with FDRS ;)
astrand1
Alex
Studio truck driver
I’m using the mongoose cable. Works well with fdrs in my experience. Have used it on quite a few trucks besides my own.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
I successfully got my ‘23 Lariat SR updated. I may have found one problem with the Forscan beta. After it installed I got the DTC for the incompatible version and loaded the as-built that @Jesse-Infotainment posted. I then restored my as-built and tried to clear the DTC. I changed the fields that @PJnc284 pointed out and it still would not clear. I noticed that when I tried to clear DTCs in Forscan the screen would clear but I wouldn’t get any message that the operation was complete. Finally I switched to Car Scanner and cleared the codes and they did not come back. I verified it with both Forscan and Car Scanner. It seems like there might be a bug in the Forscan beta in the DTC module.
Thanks to @PJnc284 for loaning me his power supply. It pulled about 63A for over 5 hours.
PJnc284
Garner, NC
11/10. Definitely good for those on the fence or anyone just interested in the process. CompulsiveCode - AsBuilt Explorer is a good tool to compare as-built files. Tried to add it as comment on the video but it seemingly went to the same black hole after posting that a comment on another channel went yesterday.
Aminorjourney
Nikki
Internet
Alas, YouTube is a pit of horribleness.
We have lost a bunch of subscribers who didn't actually unsubscribe but which the algorithm said "Nah you're done". Same with comments.
BriyGuyUSA
Glyn
Atlanta, GA
2023 Lariat ER 511A Antimatter Blue
IT Stuff
PJnc284
Garner, NC
A standard jump starter isn't going to work. You need something that can actually supply steady power. Schumacher INC100 and Clore PL6100 (requires 20 amp plug or 20-15 adapter) are the big two. Both are 100 amp. I've been using a Powermax PMBC-75 which is a bit cheaper for FDRS and the IPC mod. If you're willing to make your own cables you can get it for quite a bit cheaper.
BriyGuyUSA
Glyn
Atlanta, GA
IT Stuff
I was thinking about getting the server PSU that @Aminorjourney linked to in her video.
PJnc284
Garner, NC
That's another option and quite a bit cheaper. Just make sure you have a good set of cables. :cwl:
