BrandonSRT
Fort Pierce, FL
2023 Lightning Lariat Extended Range
I was just thinking about this the other night...drop the two setups into chatGPT and let it find it
I've tried that many times with different GPT levels and Grok and Gemini. They all hallucinate and make shit up. I'd be willing to try it again if I can get someone's as built directly off of their truck, but I am starting to have a feeling the APIM or DSP modules are different from Platinum to Lariat.
Propulsion sound settings are enabled in the APIM here:
Many have tried that and it doesn't work, I have the toggle on my screen but still no sound. If I hit the toggle, it turns the toggle on for two seconds, thinks about it, and then fails and turns itself off.
rugedraw
Javier
Miami
Auto Sales
This is sounding a bit familiar now. I remember seeing this at some point, too. I think there's a hardware element to this. Some physical component that the higher trims have........I can't remember the exact details. I'm sure someone will chime in on it.
Historically, an APIM-enabled toggle that won’t stay on was due to missing hardware or older firmware. PPOB with truck off and IIRC BC Lane Change Assist did this until other modules were updated.
Yep, has been tried before. Needs hardware. Not a software only mod. Jesse explains here. https://www.f150lightningforum.com/forum/threads/propulsion-sound.22894/post-530473
Paulb55
Paul
2024 Lightning Lariat
SFsparkie
2023 F150 Lightning Lariat ER 01/23
Can FORScan adjust GSM rotary shifter?. After problems with the OEM GSM on my Lariat (But no DTCs) I installed a new Mach-E rotary shifter. Car drives/shifts fine but there are network communication DYCs: U0203 from GSM, U0404 from ABS and instrument panel says Auto Hold System Fault. I noticed the ABS FORScan spreadsheet does show (760-02-02 xx*x xx—) Gear Shift Type (GST). But all choices read “Not Used). Is there anything That can be done to clear the DTC. (Currently will not clear). When I open the door in drive the shifter moves to Park__this may have been the predecessor to the Auro Hold System Fault. Fault remains after several drive cycles.
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 IMG_1963
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 IMG_1962
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 IMG_1961
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 IMG_1960
21st Century Truck
Martin
The rotary shifter from the Mach E doesn't fully work on the Lightning. I tried one and wrote up the results here about a year ago.
B177y
Olympic Peninsula, WA
Whole thread about which shifters work in the Lightning here.
rugedraw
Javier
Miami
Auto Sales
Livnitup added the changes needed to enable BC 1.4 to the F150 spreadsheet common tab. Same applies to the 2022-2023 Lightnings. As @bmwhitetx noticed a while back ago, the only difference between the F150 and the Lightnings is to use an E here instead of a 4 to maintain key detection alert and FRD (frunk related) as it should be for a Lightning:
7D0-09-05
xxxx xxEx xxxx
Ford F-150 Lightning F150 Lightning FORScan thread - Version 2 1782317534243-ev
This will not work if your IPMA is not updated to the latest version and this will not work if you do not have an active Bluecruise subscription and the hardware needed for BC to work.
Edit: The changes needed to enable this in vehicles outside American markets may be different, so check what values are there against the spreadsheet before attempting to make sure you don't enable/disable something that isn't supposed to be changed.
7D0-09-05
xxxx xxEx xxxx
Edit: Waiting on clarification if this change below needs to be made or if it should stay at 0.
7D0-09-05
xxxx xxxx x1xx
Sweet. So you think it’s okay now for me to add to post 1 now? We’ve been sitting on this info for a long time!
Reactions: GDN
rugedraw
Javier
Miami
Auto Sales
Oh for sure.
Added BC 1.4 to post 1. Thanks to @rugedraw for all his work on this the past few years.
bc1
McPherson, KS
Sorry but it's been a while since I've read through this thread and my memory is bad. Is there anyway to turn off the annoying keep your hands on the steering wheel warning which I get on a straight stretch of road with the cruise on? Same for the keeps eyes on the road warning when I'm looking for a particular store, etc?
rugedraw
Javier
Miami
Auto Sales
Yes, but if you do, Bluecruise will not work.
Reactions: bc1
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
Reactions: bc1
rugedraw
Javier
Miami
Auto Sales
How? Can it be used by «someone» to «disable» BC in a covert way?
No, this can only be done by plugging in with FORScan and manually disabling highway assist in favor of traffic jam assist. Basically, he would have to change his IPMA setting to what yours had before you made the changes I sent you.
Reactions: bc1
