frautumn
- First Name
- Fred
- Jun 18, 2021
- Northern CA
- 2022 Ford F-150 Lightning Lariat
I hate trying to turn air conditioning on/off with the little tiny virtual button on the bottom 15" screen in my Lariat. Half the time, I miss it and then have to pay more attention to it than I should be while trying to drive in a straight line. The fan setting is even worse, as you have to hit the tiny button and then hit another virtual button on the skinny slider that pops up to choose your setting. And if you miss the slider, you will end up changing radio station or advancing to the next podcast or whatever else is showing on your screen behind the slider. This is dangerous and I'm sure over time more than a few people will get into accidents trying to adjust these 2 controls.
My suggestion to @Ford Motor Company to fix the fan control would be to do one of the following:
* Simple fix for the slider -- MAKE IT WIDER! It's only on screen for a few seconds, so make it prominent (like at least 3 inches wide).
* For the few seconds that the fan control bar is active, the physical volume control knob could be repurposed to control the fan setting.
* The volume knob has the ability to be pressed in, and currently if you just briefly press it in, it does nothing (pressing it for 2 seconds turns the screen to sleep mode). So give users an option in the settings for what a quick click of the volume button should do -- nothing, bring up fan control (with volume knob controlling it), toggle the AC, etc.
There are many downsides to not having physical knobs, but the upside is that this stuff is all programmable, so they can make usability improvements based on user feedback, and hopefully they are doing that.
