Ford Charge Station Pro Cord Replacement
swiftshocker
Jay
Delaware
2023 Lightning, 2023, Mach-e, 2024 Mustang GT
Hi Owners. I have been reading through the threads and can't find anyone that replaced their Charge Station Pro cord. I just drove over mine and followed the following steps:
  1. Curse loudly upon seeing broken charger on the ground
  2. Attach it to car anyway and get a charging fault. Reset and same fault.
  3. Remember not to set self or vehicle on fire, falling victim to Darwin Natural Selection
  4. Decide to contact Ford for new cord
    1. Visited website: https://chargers.ford.com/replacement-parts?charger=Ford Charge Station Pro
      1. Only selling cord for the smaller connect
    2. Visit dealership parts department where a very nice man told me that the EV's are "different" and I need to call Ford as the part number does not exist
    3. Call Ford - Get transferred to the EV department and give my name, email, VIN number.
      1. General line person recommends returning the whole unit and getting a full replacement.
      2. Repeat this 5-7 times until you get an actual EV person.
      3. EV person needs to verify everything 3-5 days
QUESTION: Does anybody have a link to the Ford part, an aftermarket solution, or a used part to sell?
flypony53
Rodney
Houston, TX
You might reach out directly to @Ford Motor Company on this forum. They are very responsive.
I found this on another forum:
"Saturday I ran over my Charge Station Pro Cable/Coupler head. The part number is: Part # : SVNL3810D720AA on the Ford Replacement Parts Page. Of course it is sold out and no date for fulfillment is known. On the Coupler it says it is a Phoenix Control Product. Long Story short Phoenix Control said that their product does not work on the Charge Station Pro. I don't care as much about the two way traffic if the power goes out to the house in an outage. I just want to charge my truck. Has anyone had this problem and come up with a solution to get the 80a charge working? Thank you!"
https://www.ford-lightning.com/threads/charge-station-pro-cable-and-coupler-replacement.852/
Also, I would say IF you are not using the CSP to power your house, so that you do not need the two DC pins on the CCS1 plug you could replace the cord with an 80A J1772 cable (if you need 80A) but the 80A J1772 cords are pricey and you could just buy somebody's FCSP for less here or on eBAy for example.
I bought my FCSP for $600 with shipping and taxes on eBay brand new in the box and the original owner transferred the warranty to me by calling the 800 number.
But if you don't need the home bakcup DC pins and you don't need the 80A capability, for example if you have an SR battery you are limited to 48A anyway, you could get a J1772 cable that would handle the 48A and derate the FCSP for a lot less money than an 80A one.
Good luck!
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
I believe the original manufacturer is Siemens so you may be able to get a replacement directly from them.
lerthe61
Dmytro
Pennsylvania
F150L, VW
Today I damaged my wire with snowblower, so I have to look around for a replacement.
While I did not find a direct replacement from Siemens, I discovered that Phoenix Contact produced my wire Part No: EV-T1G2CC-AC80ADC40A-7.9M-S1S
I hope this information will help someone
Aminorjourney
Nikki
Internet
www.transportevolved.com
Ok,
So, I'd suggest that you might want to reach out to a third-party company... or rather, a company that makes the cables in the first place.
Try Phoenix Contact ?
I can state for sure that the charging cable CAN be replaced (based on my time inside the FCSP there's nothing hard-wired for the charge cable).
The link I shared IS NOT suitable for the FCSP as none of these have the AC pins present, but I bet someone at Phoenix Contact will know the exact model? Alternatively, the ones I've linked do have empty spaces FOR an AC pin I believe, so I think you could make it work.
EVpower
Steve
Northern California
2023 F-150 Lightning Lariat, Bronco II
Electrical Engineer
I found a couple of possible replacement plug & cables at Digikey.com which list Phoenix Contact EVSE products. The stock number is 277-1101121-ND which appears to be a direct replacement lists at $1030.01 Each.
If you are not going to use the FCSP with HIS, there is an AC 80 Amp only cable with stock number 277-1277166-ND with a list price of $339.00.
I'd replace the FCSP with a better unit and donate it to someone who wants to reverse engineer it.
Steve
Scorpio3d
SS/IBA car wash owner
Steve
I found it on Radwell as well:
https://www.radwell.com/Buy/PHOENIX...1G2CC-DC80A-7,0M6ASBK11?parentitemid=30676597
But I agree just replace it with something else!!!
Runaway Tractor
Yes
This is getting too complicated. Simply google "80 amp J1772 cable" and you will find what you need. Leviton and a few others have them. Bonus, you get a less bulky cable without the DC wire for the HIS. You will need to open up the FCSP and properly terminate the new wires on the lugs. Close it up. Done. Enjoy.
Make sure you get an 80 amp cable. The cheap commonly available 48 amp cables will melt at 80 amps.
farmtruck
Pierre SD
22 F350XLT, 2 x 12 F250XLT, 23 Lightning Lariet ER
Farmer
If you are going to replace your FCSP cable with aftermarket, use a J1772 cable.
CCS1 cables use smaller wires on the J1772 side of the plug. The pins that are used for power transfer with J1772 are used for communications on CCS1.
