cdherman
- First Name
- David
- Jul 18, 2023
- Kansas City
- RAV4 Prime, 2016 Leaf
OK, background.
-- Installed January 2024, 100A service, directly from 200A main. Outdoors. 100A breaker, correct wiring all per install instructions. Polaris splitters.
-- could not get the wifi to connect that day, but it charged fine at 16.8kw or so per the truck display. I was worried the local line feeds were 2 legs of 208 three phase, but I did not have my multimeter with me, so I could not verify.
-- worked fine for 18 months or so, no wifi and as all things are, I never made it back to figure out the 16.8kw charging rate.
-- It still charges fine on other EVSEs, just not the FCSP.
Now:
-- my brother calls me that he's getting a steady amber light and no charge. He finally gets a wifi extender and connects to Ford Pass. "Installation error, contact your installer" Guess that's me.
-- I go out today. Some moisture in bottom of box -- more like condensate. Dryed it out with blow dryer, GENTLY.
-- checked all voltages -- 250 at all points. At 200A breaker, at 100A breaker, and at the lugs in the FCSP
-- killed the current and check torques of lugs. All good. No discoloration or damage either.
-- derated it to "3" and tried to charge. Same error. Unit reverts to solid blues between attempts.
-- tried to charge with a finger on the relays -- both definitely are activating, and the error happens right then.
-- tried the "factory reset" button in the unit. Stayed white afterwards for a long while. We tried to plug in -- usual error, and then back to blue when we unplug.
Not yet tried:
-- I read later that his charge setting have gotten set too low in Ford Pass. We did not check that. BUT, I would think that a factory reset, where Ford Pass is no longer connected would have fixed that.
-- Read later about firmware update. He had the Ford Pass on his phone, and I did not look for that option at the time. Guess we need to reconnect the FCSP to the internet and Ford Pass and find out,
Still unexplained:
-- why was the vehicle reporting 16.8kw charging with a V of 250? Or did the utility fix this from an earlier 208 value? No idea. Anyone can explain? I *should* have went back to figured this out at the time, but you know the saying "Let a sleeping dog lay".....
Tomorrow we will reconnect to Ford Pass and explore the firmware thing. After that I fear its a call to Ford. Does this thing have a warranty? Installed by an un-licensed installer? Worried.....
Now:
Not yet tried:
Still unexplained:
