Hot Spot
tcfila
St Louis
2022 Lariat ER
Now that I have 4.1.3 and youtube, I'd like to use it!
I have not activated the hotspot. Is it possible to activate the hotspot and have the truck connect to it? Any other options, other than hotspot to phone?
Thanks,
Tim
Thanks,
Tim
No, I actually started my trial session of the hot spot thinking this would work, but it does not, I am letting the trial expire, then will possibly subscribe to streaming entertainment, which is what prompted when I tried playing YT while charging at EA last week.
I set up my android device as a hotspot to the truck then YT started playing.
You would think the truck would take advantage of it's built in active hot spot but that's NOT THE CASE @Ford Motor Company
Nope, it won't use its own hotspot. Connecting to your phone's hotspot, OR connecting to any WiFi network (restaurant, hotel, home) works fine.
jerock
Jerry
Kansas
F150 Lightning
It works quite well with my home wifi & the hotspot from my Iphone.
jerock
Jerry
Kansas
F150 Lightning
I can no longer connect to my Iphone's hotspot to stream entertainment. I just get the message unable to connect. Has anyone else had this problem?
jerock
Jerry
Kansas
F150 Lightning
Iโ€™ve been trying
To get the WiFi hotspot from my iPhone to work for a couple of weeks now & today it connected. Guess I should have posted earlier!
I let the hot spot expire as planned early this month, but I did subscribe to streaming services which is working well, now that motorcycling season is here, I won't be using the feature much either, might suspend it until the fall/winter
mr.Magoo
2022 Lariat ER, AMB
You can get a wifi travel router from a well known online retailer.
They're small and are powered off of the USB port, cost is $25-40 depending on features and requirements.
Connect it to the hotspot and the truck to it and voila, the truck can now utilize the onboard hotspot.
A-s backwards, yes, but it works.
