How are we holding up?
AZT9
Peoria, AZ
Hey all my Lightning peeps! I’m a little bummed that Ford pulled the plug on what has been the best truck I’ve ever owned. That said. Wanted to know how our aging fleet is holding up?! I personally am finding that yet again people’s fears of these amazing trucks early demise is unfounded ( there will be exceptions with some issues and module failures reported) gotta keep in mind that all manufacturers seem to have issues petrol
Or not.
My stats are as follows
2022 F150 bought new
100,350 miles
Frequent DCFC due to long commute to work
Overall SOH 95%
module variance .21%
module voltage delta 0.01
Daily charge set to 80%
Curious to see what my fellow Lightning owners are seeing after the last few years🤙🏼
The Weatherman
Dean
South Central KY
2022 Lariat ER - 380mi Demo March, 2023
21700mi.
Test DC charging only (home charge to 90%-ABC)
SOH 98%
The Weatherman
Dean
South Central KY
I’m sure my frequent DCFC sessions have a penalty
Maybe, but these are holding up way better than the experts thought they would. 😊
chriserx
Louisiana
2025 Flash bought late July 2025
16,400 miles already, it's such a pleasant drive...I can't help but use it
Charge level set to 100% but use a tapered charge so it slows as it fills, usually use at 60-80% except road trips.
SOH 100%
Haven't checked variance in a while but it was negligible, usually get to 100% couple times a month.
Maybe 50 or so DCFCs
Towed for first time this week, range sucked esp for such a small uhaul motorcycle trailer, but not unexpected.
Also slept in the truck with AC running this morning, 2.5 kwh for 4 hrs of comfort, slightly better than expected.
Except for not buying the trim I really wanted, extremely happy so far.
OMO7
23 Lightning
There a way to check SOH with the Mongoose dongle or you need a bluetooth OBD reader and app?
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
‘23 Lariat delivered November ‘22, 28k miles. Daily charge to 80%, 100% for road trips and lots of DC charges while traveling. Current SOH is still 100%.
Ford F-150 Lightning How are we holding up? IMG_0249
AZT9
AZT9
Peoria, AZ
I use the car scanner app to read the internal data with a Bluetooth OSB dongle
AZT9
AZT9
Peoria, AZ
‘22 Lariat ER 79,521 mi.
Delivered as ordered 11/13/22
More or less equal mix of fast and slow charging to 90%. Not concerned with SOH.
Best truck I’ve ever driven!
Ford F-150 Lightning How are we holding up? 1775956359667-p
22legit2quit
2024 Ford Lightning Flash ER
2024 flash, purchased new 11/24. 24k miles, 100% soh, almost never dcfc. Mostly charging at home when I need to I try to drive it a few times per week because I drive a different vehicle to work. 2.4 mi/kwh average to this point.
all in all the best truck I’ve ever owned be that gas or diesel as well. The whole range anxiety thing is lame but I can understand the newbies issue with it. Eventually adding the generator kit whenever that comes available. No real issues other than the ridiculous amount of updates, recalls and strange behavior the truck does with sport mode.
These are gonna be keepers, the other communities for evs, especially the trucks (ct, rivian, gm) aren’t like this. Which is a plus. People will figure these out like my other soon to be partial ev Honda insight. So stick around things will get better than they already are. Cheers!
AZT9
AZT9
Peoria, AZ
I think that this truck is going to become coveted in the next year or so. Ford may have pulled the plug prematurely 🤷
FORScan, oscilloscope tool, double-click an empty square, choose HVBAT_HEALTH, %
Ford F-150 Lightning How are we holding up? 1775959216604-ca
F150guy
Garrett
2024 Lightning ER Lariat
24 Lariat. 31k miles. Charge at home 99 percent of time. I haven't and don't care to check SOH yet as my mental gyrations and calculations say it's doing fine. I have an OBD device picked out for telemetry purposes just need to pull trigger.
I've had only recall stuff/fixes and a new heated steering wheel. Tire rotations, cabin filters of course.
My only complaints are the floating front end feeling sometimes.
Sure, software is weak and lacking, but it does work. No issues with the updates and none also with the 12v batt.
S
