I charged to 100% and my Lightning said 379 miles!
lipnorth
lipnorth
Connecticut
2023 Ford 150 Lightning Lariat
I have t noticed a hit from AC but the heater make a huge difference
I have been messing with the GOM over the last few days too.
My thoughts
The GOM uses a short term rolling average, maybe 5 or 10 minutes. But, above 80% it starts adding a bias to make the range appear more optimistic (or uses the previous average from the typically slow driving the few miles before home).
I just observed my GOM actually INCREASE in range when going from 55mph roads to 35mph roads. I also observed the GOM dramatically slow its loss when turning off HVAC.
It uses hundreds of miles.
I just returned from a 70 minute drive monitoring the GOM and watched the GOM go UP when my speeds changed from 60mph to a 35mph drive through town.
When traveling down country roads I was loosing about 12 miles per 5% SOC lost, then on more steady 60mph stretch with the HVAC on high that was 18 miles reduced for a 5% SOC reduction, then it was a 5 mile reduction for a 5% SOC difference when my speeds dropped and i turned HVAC off. It was definitely adapting in the short term.
FloridaMan655321
1973 F100, 2024 Flash
Pics or a lie, internet rules established in 1989.
I usually do a little calculation when I power up to my normal 85%. It's often over 300, sometimes over 320 pending how my drive has been as of late. When I drive to a park nearby I'm always around 4miles/kwh. I should do that for an extended period of time.
Yes, it adapts constantly, but it isn't based on 5 or 10 minutes as he said. If it was, it would jump drastically.
It uses hundreds of miles for the estimate when you start, then as you drive it evaluates if it is different, and adjusts. Think weighted average with more weight on the immediate driving.
Reactions: EVO
I can guarentee it does not use hundreds of miles when you start. I just posted a thread discussing getting to a low SOC. To achieve that, and Immediately prior to charging up from that (to 100%) i took the battery from 38% to 5% in a single highway drive of over an hour with speeds over 70mph (so around 1.9-2 mi/kwh). My trip1 has 5000 miles on it with an average of 2.1 mi/kwh. I typically average around 2.1 on my daily commute. Yet when charging to 100% it showed a range of 347 miles and an energy to empty of 131.5, which calculates to 2.64 mi/kwh. The starting estimate was nothing like any of my previous drives would explain.
Piquette
Trent
New Hampshire
2022 Lightning Lariat
The GOM is more of a distraction than it is a navigation tool. I keep my eye on the mi/kWh and the remaining percentage battery charge. The mi/kWh varies tremendously depending on the ambient temperature and the terrain. Last February we had a day where the temperature was about -18 degrees Fahrenheit. Mi/kWh dropped down to about 1.5 and I abandoned my planned trip for the day after I tried to add some charge at my Ford dealer’s high speed DC charger and found the cables too stiff to even get them to plug into the truck. In contrast, now that warm weather has returned I am getting 2.9-3.1 mi/kWh which theoretically gives my ER Lightning 360-390 miles of range.
And I always get better mi/kWh going down hill than up. 😊
CD4TNF
I just use @invertedspear 's calculator for range, battery %, and the dash mi/kWh.
https://lightningcalcs.pages.dev/?battery=131
The truck doesn't know the future, only the past.
I plug in 1.9mi/kWh and the battery % into the calculator. The 20% range it spits out I'll feel comfortable with.
Robert1380
Robert
Retired law enforcement
Why reset driving history? Just ignore it altogether. I wish they would just get rid of it, it's meaningless. Nobody has ever benefited from knowing how far the truck thinks they could have gone yesterday. If you drive super slow one day and it says 370, then get on the expressway, you aren't going anywhere near 370 (if driving highway speeds).
I know it's beaten to death, but man, I don't know why people care about that number. The only one that matters is battery percentage.
I think people care because many of us have been driving ICE vehicles for most our lives and are programmed to watch that “miles to empty” section of the info display. It’s hard to separate the current battery percentage from the miles. As it’s been explained to me, the percentage is really what matters and that miles function is a false sense of security. Gotta be a better way or possibly dump the miles portion altogether.
MaintGrl
Marsha
El Sobrante, Ca
Both of my other vehicles (Current 96 Ranger XLT and totaled 06 Taco 4x4 ) did not have any range calculations in the displays, so the GOM is new to me....
Robert1380
Robert
Hell, I think every car I’ve owned over that past 20 years had “miles to empty” countdown on them. Even our police cars had em.
Brent@ANParts
Diamond Sponsor
Brent
www.autonationparts.com
Ford Bronco
Marketing
EVs are so volatile with their range numbers, I wish I could comfortably go by the battery percentage instead, but my brain just won't allow it. I can understand half a tank on a gas car, but 50% on an EV could mean 75 miles or 150 miles, depending on so many factors.
Robert1380
Robert
Yep. That’s pretty much what I was saying. We are programmed and our brain says you got 319 miles on the meter then you got 319 miles of travel depending on what type of lead foot you have. Gotta learn to disregard that I guess
