Lightning 20" AT vs AS tire option. Does anyone have info about these tires?
sotek2345
Engineering Manager
Looking at Tire Rack today, I see that the 2022 F150 lightning is now available as a vehicle selection. Filtering by the 20” option, and OEM, shows an AS tire that is the Good Year Wrangler Territory HT and the AT options as the Hankook Dynapro AT2 or Pirelli Scorpion ATR.
Good catch! Those all seasons seem to have pretty good reviews.
syrc
San Francisco, CA
2021 F-150 Lead Foot Lariat 3.5L PowerBoost
does anyone know if the usual truck tire options work fine for ev or are we limited to tires designed for ev? i keep reading about need for ev tires, but since no real market for them yet i don't see anything on the market.
rodhx
Rod
Alabama
21 Mach E 4x, 03 IS300, 06 Ridgeline
Any tire suitable for the vehicle weight will be just fine. An “EV” tire *might* get you a bit better range, but ultimately an EV is just a heavier-than-normal car.
VTbuckeye
Joseph
Vermont
19 Bolt, 16 XC90T8, 22 XC40 P8 Recharge, 17 Tacoma
Heavier, more torque and quieter, so it in theory will require a more durable tread due to the weight and torque, but to avoid slipping with the high torque it will need to be soft enough to hook up well. All the while not having too much tread noise because there is no ICE making noise.
Just get what you like knowing that it will be louder, more likely to spin when accelerating aggressively and will wear out faster.
beatle
Springfield, VA
EV tires often have LRR (low rolling resistance) and have lousy traction when compared to even all season tires. I had Michelin Primacy MXM4 tires on my Model S which were the OEM tire. They were indeed quiet and comfortable and even had enough traction for launches, but they were awful during panic stops and cornering. I now have Michelin Pilot Sport A/S 3+ tires which have greater cornering and braking traction. They are just a touch louder (not offensive) and they are 4-7% less efficient than the MXM4s. I also run Firestone Destination A/T tires on my Ridgeline. They perform in all conditions very well, but my mpg has always been well below average with them.
There are currently only a handful of tires available that check the "Eco Focus" box on Tire Rack. It's interesting that Ford did not choose one of those as OEM for the truck given the importance of maximizing range.
sotek2345
Engineering Manager
I will second the capabilities of the A/S3+ tires. I have them on my GT350 - that said, I don't think I would ever use them in the winter - they just do not preform in the snow/ice. Great 3 season tire though.
We have been very pleasantly surprised on how good the stock tires on our Mach-e GT are (Continental cross contact). I was prepared to swap them out for something better in the snow, but they have been wonderful - the car is a beast in slippery conditions.
Yellow Buddy
Mid-Atlantic
Smart Ass
The biggest thing to be careful of is the weight ratings. Otherwise, I moved away from an “EV” tire on my Teslas a while ago.
In some cases the noise was higher and the efficiency worse (snow/winter tires) In other cases the handling got better and the efficiency worse (high performance summer) and in some I’ve even gotten better efficiency out of a non-EV AS package.
The only thingI’ve noticed out of an EV tire is really the foam insert for noise reduction. I usually drive with a radio on so it hasn’t made much of a difference to me.
astricklin
Dallas
99 Mercury mountaineer
Even though the tire model may have the same name, it is highly likely that Ford will have a special version created for the Lightning and the ones that come on it at delivery, and ones that you can get today at TR or another retailer will have different characteristics.
ExCivilian
'05 RAM 2500 5.9L Cummins; '22 Lariat ER
I haven't seen any manufacturer do this other than Tesla. I'm not even sure about Tesla, I just read that they have foam or something in their tires so I'm assuming they're custom made.
Everyone else, however, is using off the shelf tires.
There have been many special EV tires created - all aimed at lower rolling resistance.
People freak out over the foam in the tires of a Tesla. That was actually meant to make the tires quieter. In my opinion it doesn't work, but it freaks tire shops out. You can easily cut it out to fix a flat and then just a quick rebalance of the tire and done..
beatle
Springfield, VA
These are for Rivian who worked with Pirelli on the tires:
Ford F-150 Lightning Lightning 20" AT vs AS tire option.  Does anyone have info about these tires? 1648828141077
Ford F-150 Lightning Lightning 20" AT vs AS tire option.  Does anyone have info about these tires? 1648828168729
Neither are Lightning sizes, but perhaps you could run a 275/65 on the stock 20" wheels. Your speedo and likely range prediction would be off a bit though.
Silenze
Wi
If you look on tire rack the hankook dynapro at2 have a special ford tread pattern for the lightning.
KniceHit
Buffalo, NY
2015 Ford F-150 Lariat 5.0L
That is the answer right there. This video confirms that is the tire being used.
