Motion detection
Sobmartin
Bill
Washington state
2016 F150 2021 Mach-e er
It appears the the Flash model doesn’t have the motion sensors like my Mach-e does. The online manual say where to set it but it’s not in the menu.
I don’t think we have it on any trim level. Thankfully.
My 2022 Lightning Lariat-ER has an option for the Security System just above the Remote Start Setup section.
I can enable the truck to ask me to activate it upon exiting the truck, and a sub option to turn the IR sensor/detector on/off.
Ford F-150 Lightning Motion detection 1733880465818-e8
Not sure if Pro & XLT had this option in 2022
Might not be a feature for 2024 Flash.
BTW, I turned it off, as it was a nag to deal with, I park in a secure home garage.
Scorpio3d
SS/IBA car wash owner
I think on the 23s it was a delete “advanced security pack”(Or something like that). I don’t know if that is the same thing or not?
IIRC that was the situation, wild to think that supply issues for that feature might persist.
Scorpio3d
Maybe they just decided to make it a permanent delete since they are trying to cut costs??
I was thinking that, but why didn't they delete references from the 2024 owners manual?
Ford F-150 Lightning Motion detection 1733891616838-mn
Scorpio3d
Hmmm……
Good point however they also say that you can charge higher than 48 Amp on the new trucks from my understanding…
Maybe they should just quit deleting stuff!???
Hmmm……
Fleet models can still be configured with 80A charging.
Henry Ford
The supply of unlimited money for EVs at Ford dried up in about 2022.
Artie, the Ford Manual writer, retired and hasn't been replaced.
Whitewater64
Scott
Palm Springs, CA
MY 23 F150 Lightning Lariat ER Max Tow Star White
Singer/Conductor
Doesn't the manual also tell me how to turn on the remote window down function on my '23 Lariat? To my knowledge, that doesn't exist unless you tinker with Forscan (which I haven't had the courage to play with). Living in So Cal it would be great to be able to remotely open the windows sometimes to replace the 125 degree interior air with 120 degree air from outside. :cool: AND what I'd give for walk-away locking. SIGH.
Scorpio3d
Walk away lock will come in an update! Whether that is with FDRS or OTA.
