New owner ….
RustyMitchell
James
Anthem Arizona
F150 Lightning
I give up!
1) Where do I set the target max status of charge ?
2) How do I activate LoJack ?
Thanks in advance
Rusty
When you plug in somewhere, you can save the location. Max charge limit is per location.
Note the location based charge settings/limitations are for AC charging.
DCFC charging is done on a session by session basis on the CHARGING menu, the default is 90% but you can adjust as your needs vary.
astricklin
99 Mercury mountaineer
If you purchased the LoJack system at your dealer then they should have provided you with paperwork for it.
