New sensation: :NOTHING from the 'gas' pedal : / out of juice!
well, tonight it happened...
I've wanted to know, for myself, what 'really' happens when you're out of juice, and tonight the exercise was for real.
146 miles from a DC Fast Charger to my son's home... ooops. Forgot there were 'mountains' in between : /
The whole route from the Chargepoint units in Ft Payne, AL(Home of the almighty band: ALABAMA!) to my son's home
in Young Harris, GA, the 'guessometer' showed a low, but positive, 'miles available' versus the required miles to reach.
Until the mountains got in the way.
Well, I'd been wanting to know, anyway, so here's a good test.
Everything was pretty fine, as I drove cautiously most of those 146 miles. The last 10 were different, though.
I could feel the need for more pressure to the pedal to maintain the same speed. Something was happening, a revelation
especially on inclines. 5 miles out and it was REALLY slowing. Pushing the pedal did nothing to change it. It was going to only
go what it wanted to go. After reaching the top of the hill, going down the other side was fairly good, although mainly due
to gravity.
I knew I could 'make it' to my son's home, mile wise, but I was concerned about the last 100 yards to his driveway. His home
sits on the 'top' of a hill. Coming off the main road to his driveway is 100 yards of 25% grade. I knew THIS would be the test.
It was. It failed. The truck, even with a LOT of speed and momentum just did NOT maintain any speed once we pursued the
incline. It was done.
Oh, no. What now. I'm in the street. I'm in the way. I'm on an incline. Can it be any worse. It's 11pm. It's dark. Not good.
Since I had not gotten very far 'up' that last hill, I decided to put it in Neutral, and led it 'slide' back down to the bottom, when
I had come off the main road. I was able to use that momentum to actually turn 'around', heading the other way, and looking
across that main road to a farmer's field. I said to myself that it would be the place to park, and then I could gather my thoughts
and look for a solution.
Interestingly, though, as I allowed the truck to 'roll' in the edge of the field, just off the road, when I stopped and put it into reverse
to better 'configure' where the truck would sit for the night, I realize then that REVERSE had power.
Well, let's give THIS a try, then!
I kept it in reverse, I REVERSED BACK ALL THE WAY UP THE STEEP HILL INTO MY SON'S DRIVEWAY, and plugged in for the night : )
One may never know why 'forward' did not have power, but REVERSE did. Nice to know, when in a pinch.
Firestop
Firestop
That’s what I love about this forum….learning about people’s solutions to problems….not just bit**ing about problems….
Nice job!!!
HaroldCal
Harold
Las Vegas, NV
I would bet that this is, at least in part, a software thing. My edumaguess is that Ford put code in to limit the power in forward when the battery gets low, but didn't bother to make the same code apply in reverse.
GarageMahal
JT
Minnesota
Data Wrangler
Awesome discovery, thanks for sharing.
I suspect when you got reduced power, the turtle icon was on your dashboard.
trev5150
Trev
Pilot of pilotless things
Hope they don’t “fix” it then. I suspect they did it deliberately to get you out of precarious situations, allowing you to get into the secret squirrel ~2% reserve.
Oneand0
Mario
South Lake Tahoe
Digital Investigator
If you guys ever see me driving in reverse through the mountains of Lake Tahoe, you know what happened. ?
vandy1981
Tennessee
Plumber
@OutofSpecKyle and @tommolog need to add this to their 70 mph road test protocol. After the battery is depleted in forward 'gear' they should switch to reverse to get the true range estimate. :LOL: :LOL: :LOL: :LOL:
4Reeley
PA
Lariat
Did you GOM read zero miles before you got to your destination? Wondering if it is like ICE vehicles where you continue on zero for some time. Did you lose accessory power at any time or is that all run on the 12V? Do you think you gained any regen distance on your roll down the hill?
Tomwilli2025
Alabama
Sales
Thanks for sharing this.
