dmd3home
- First Name
- Dan
- Apr 20, 2022
- Central Coast CA
- 2023 Lightning Pro, 2014 Spark EV, 21 Tesla Y, 2018 BMW X5 phev
So I've been paying close attention to my 12v battery which certainly seems a weak point in our trucks. To minimize problems, I, like many, keep the battery on a maintainer when it's not being driven. To monitor even more precisely, I've added a VOM voltmeter. In watching this voltmeter in various situations I've observed some strange results. Normally you'd see a fairly steady 14.5v or so but in this situation I had the maintainer off (unplugged) and I was charging the truck's HV battery via a level one 120V solar/battery/inverter system. As you see, the 12V battery voltage varies wildly...with values of less than 1V to about 14.5V. At first I thought my voltmeter was failing me so I tried another....same thing. I was measuring the voltage directly off the battery posts so I thought perhaps I needed to measure downstream of the battery BMS. But, trying this produced the same result. But, when disconnecting from the level one charging, the 12V battery voltage shows a more normal and stable 12.5V to 14V. It obviously the had something to do with charging the truck
Why would the measured voltage have such swings? What is really happening here? Logic would suggest that the only way the measured voltage could momentarily drop to less than one volt would be to have a high load on it. But that wasn't the case. The 12v battery, although quite small, should provide a relatively stable voltage under any condition. Strange! Are there some added high frequency pulses to the 12v battery that are fooling my meter? Strange!
