- First Name
- William
- Jan 8, 2022
- rural Georgia
- 22 LIGHTNING PRO IcedBlueSilver 8/23/2022
- Occupation
- Owner
no, a NEMA 14-50 4-prong outlet is not 'wired with only 120v', it is 240v, with two hot wires, a neutral, and a ground. Campgrounds don't wire it differently 'just because' all RVs don't need 240v, because some DO. Motorhomes and large fifth-wheels, and actually even some towables use 50amp 240v power. The pedestal they plug into IS 240v. The outlet is wired to a double-pole 50amp BREAKER, for 240v power.... some campgrounds are wired this way, because many 50A RV's only need 120V. So they bring only 120V to the pedestal and wire it to both sides of the receptacle...
Where the difference between your Home's panel and most 50amp RVs is simply that the RVs might not have 240v appliances, and the RV's breaker panel doesn't use any 240v breakers, but it still has 240v power coming into it.
The difference is that RV panels can be designed to use both '120v sides' of the power, separately, ultimately providing up to 100amps at 120v, so that running two overhead air conditioners, the microwave, and everything else at the same time is accommodated by that amount of power.
The more common 30amp RV outlet IS only 120v, and therefore doesn't support many of the larger RVs that we see today.
Like FORD, the RV industry started accepting the NEMA 14-50 240v outlet as the standard many years ago, whether for large RVs, or EVSE equipment.
Otherwise, yes, 240v service is 240v service, whether from your utility, or the campground outlet.
If it's a 240v outlet, it's 240v power.
