Reverse Sound
Deleted member 19221
Guest
My Lightning makes zero noise in forward motion, and I've even startled people while pulling up near them in a parking lot. In reverse, I want a sound to be made so people will know I'm backing up. I do understand why one would want to temporarily block the reverse sound, but that sounds is hardly as loud as a V8 or turbo diesel.
reddog21
MA
It's one of those stupid laws enacted by a stupid government bureaucrat. There is NO law against the consumer modifying the vehicle. Only those that make and/or service same.
Not true at all, pedestrians are 35% more likely to get hit by an EV than ICE. All major countries have the same requirement this is not specific to the US.
It is 100% against the law for a consumer to modify any auto safety equipment.
NeighborGeek
Steve
2025 F150 Lightning Flash
IIRC, the 2025 trucks have a different sound that is a softer tone. Either way, it’s still annoying to everyone around you when you’re hooking up a trailer at a campground in the morning.
Every time I see a complaint about the reverse sound I wonder what people are talking about. Maybe this is why, I drive a 25 Flash and have never noticed any sound when in reverse. Maybe there's something like the same sound it plays when in drive and I just haven't noticed the difference, but certainly nothing as obnoxious as other people seem to experience.
P-38
2024 Lightning Lariat
Interesting...either you have hearing problems or something is wrong with your 25 or they don't use the same sound in 25....
It is a loud backup alarm like what you find on job sites. It's different/new to people on a passenger car but common on larger trucks. It is annoying at 3AM but I have no plans to eliminate it.
Now a better forward motion sound...that would be nice
NeighborGeek
Steve
Nope, I definitely don't have that.
PJnc284
Garner, NC
Maybe they adjusted it on the 25's after all the complaints. Swear you can hear my 23 from a block away when backing up.
21st Century Truck
Martin
I used this Brigade Electronics directional Shhh Shhh sound (no piezo beep!) on my last several gasoline cars, to good effect and without causing annoyance to others.
It's a simple bolt-on to any metal bolt in the rear, and a wire tap into the reverse light... an easy - peasy installation if you can turn a ratchet and choose a socket.
https://brigade-electronics.com/en-us/warning-systems/backup-and-warning-alarms/
No need for it on the Lightning, of course.
Athrun88
Toronto, Ontario, Canada
Any way to set it up so we can toggle the reverse beeps? I was thinking of just wiring in a switch but wonder if there's a more eloquent way of going around it. I'd want to do the same with the frunk beeps as well.
Maineiac12
Iowa
Yup! You’re lucky. I’ve driven a 25 F-150 and a 25 Mach-E as service loaners recently and they both have a more pleasant and less obtrusive backup sound. Maybe someone will figure out how to change the 22-24 vehicles because they sound like a garbage truck backing up lol
Heliian
I have a 23, you can't even hear it with the windows up
It's also the same sound Ford used on its other trucks.
