Shifter Squeaking 2022 Pro
chrislittle
New Hampshire
Mustang Mach-E, F-150 Lightning Pro
Has anyone had the squeaking (video below) when shifting their lightning? its gotten worse over time for me. Could I put WD40 in that area or am I going to regret that?
kbuicker
Kevin
Dallas Texas
2022 Lightning
Have you checked the rubber piece in front of it, maybe it's out of alignment? Does it move left or right? Maybe someone pulled on it?
StrikesTwice
Miami
2017 VW GTI / 2005 Dodge Ram 1500
It’s the interior of your truck. Don’t use the standard wd40. It’s oily and will attract dirt. If you’re going to use a lubricant, use a dry lubricant.
chrislittle
chrislittle
New Hampshire
thanks everyone. things don't seem too out of place but I'm going to take it to the dealer as lowering the shifter makes an even louder sound so clearly the trim must be off enough to make noise.
Ford Motor Company
Official Ford Account
F-150 Lightning
Good morning, Chris! I would be glad to help you out with this squeaking concern if you'd like. Just shoot us a direct message with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
Wd40 is electrically conductive, never use on electronics.
The shifter shouldn't be squeaky, it could be a misaligned trim like @kbuicker said.
WD-40 has a dielectric strength of 35KV. It’s not conductive. One of its common uses was to spray into the distributor cap to displace the moisture.
Yes, it was advertised like that decades ago. I still wouldn't use it on sensitive electronics.
Agree - I can’t really think of a reason to use it on electronics, but if an electro-mechanical device requires lubrication, it would be fine to use.
HJP
F-150, F150 Lightning, DMG Mach-E GTPE
My Lariat trim does the same but not always. Have not been able to find a reason for it. The trim looks OK and it's not always. Forgot to ask last time it went to the shop but based on history won't be long before it goes again and will ask.
