'Sounds' from the otherwise 'quiet' LIGHTNING...
all EVs have some sort of built-in, sometimes customizable, 'sounds' that the vehicle makes at low speeds, and when backing, for pedestrians to 'know' that you are moving....cause, after all, the truck otherwise will make NO 'noise', other than the gravel or pavement underneath the tires....
have we heard ANYTHING to allude to the 'sounds' that the truck makes? I've not seen any videos where someone is there to capture anything while the truck is moving slowly, or backing...
by the way, my Leaf makes that infamous 'jetson's' sound at low speed, and a more annoying 'beeping' sound when backing.
rdr854
Northern Virginia
I test drove an MME that had a faint back up alarm.
Royalist
Nabil
Russell Twp., OH
'22 Land Rover Defender 90 S
Student (Aviation Management and Operations) / Farm Manager
“quite”
or Quiet, which means almost silent
TRP
Tim
TN
2021 Mach E Premium 4X, 2018 Ford F150xlt Sport
Most likely similar to the Mach E. It has a back up beep as well as a slow speed "humming" sound for bed warning. You have to listen carefully inside the car to hear either, radio off or turned low helps.
I had mine several months before I knew it had the back up beep.
Oh, nothing is adjustable or programable on it either
pstansel
Paul
Tolland, CT
To be fair there's a ton of Telsas (mine included) that don't have those sounds. They weren't required to add them until sometime late 2019 I believe.
Reactions: GDN
metroshot
Pat
Montclair, CA
2022 Lariat F150L + 2023 MME
Networking Tech
My 2018 Honda Clarity PHEV has a hum that sounds like a zen religious chanting group would hum with...
I like the hum that sounds when driving slowly on EV.
OTOH there are Clarity forum threads that show how you can cut out the speaker that is under the hood...
Sklith
Georgia
The only vehicle I've witnessed that has an annoying sound coming from it is the Kia Niro, it's reverse beep is way too loud.
our LEAF is not annoying, for the backup beep anyway, but I just hadn't heard any feedback from any drivers, passengers, or videographers about what they may be 'hearing' from the Lightning, if anything - silence is just perfect for me, but I have a feeling that there are actually rules that EV manufacturers have to build-in to provide pedestrians 'notification' that the vehicle is moving...
my LEAF also has the 'jetson's' sound, in Drive, from the moment you start moving, up until about 16mph...
Skidrowe
Gideon
My current EV makes this sound as it approaches you, passes, and drives away:
Regular150
Shawn
Purchasing
Go by Ford dealership and listen to a Poerboost. Same sound when it's in EV mode.
