MidAtlanticLightningClub
Yep. That's why the rear starts high. The truck is ready for work.The truck looks nicely levelled with that trailer ;-).
A properly setup weight distributing hitch will not significantly change the rake of the tow vehicle. Ideally you want less than 1/4" difference in squat between your front and rear axles.Yep. That's why the rear starts high. The truck is ready for work.
I've done it at more than 50 different campgrounds in three RV road trips. Most pedestals have 1x50, 1x30, and 2x20A outlets. I'll plug the truck into the 50 and the trailer into the 30 (we have a 30A trailer).Are you able to use the Ford Level 2 mobile charger at the RV pedestal to charge off the 50Amp RV outlet without an adapter? Seems like that should work?
Step 1: Plug the trailer into the 30A.
- I have been to two campgrounds that said they didn't allow EV charging -- I usually check their website, etc. first before reserving.
Last summer I stayed at a few campgrounds, that to charge, you needed to rent two spots. One for camper and one to charge truck.Hummm… sounds like it can be a little sticky. So don’t show up with 20% needing a 100% for the next leg. Have a plan B charging station near enough. Maybe RV parks will loosen up or even tack on an extra fee to fill up your EV. How often do you get “banded from the campground? Thanks for the feedback. HT
Thinking out loud. You could always plug the RV into the campground pedestal and use your Ford Mobile charger plugged into an RV 120vac outlet, assuming you have a 50 amp capable RV.Last summer I stayed at a few campgrounds, that to charge, you needed to rent two spots. One for camper and one to charge truck.
I plug my truck into the 50A and plug the RV into the Pro Power Onboard 30A.Thinking out loud. You could always plug the RV into the campground pedestal and use your Ford Mobile charger plugged into an RV 120vac outlet, assuming you have a 50 amp capable RV.
Alternatively you could plug your mobile charger into the pedestal 20 amp outlet.
Slow but free.
