Updates and features not working correctly
The suggestion to delete the home charging station and add it again causes me anxiety :) The setup of the HIS system is so finicky that I may be opening Pandora's box - oh well, I have nothing to do for the next 8 hours - here goes...
Changing {delete to redo) your charging profile won't affect configuration of the FCSP & HIS!!!
idahospud
idahospud
Idaho
2022 F150 Lighting, Indian Roadmaster
Commercial Real Estate
Changing {delete to redo) your charging profile won't affect the configuration of the FCSP & HIS!!!
I think i am confused. When you reference the charge profile, what are you referencing? When I deleted the FCSP from the system, I then did a reset to allow the system to be found and re-paired with the truck and Fordpass. This also results in the need to re-pair the HIS. (both processes using the charge station pro app).
Sorry for the misunderstanding, I was out all day on a MC run so missed your follow-up posts.
Fordpass, Energy tab, Target Charge function, select the location named profile, DELETE.
That's all you should have done, not change anything related the FCSP configurations.
Ford F-150 Lightning Updates and features not working correctly 1752509198425-gf
Though it's a lot easier to do in the truck on the Sync screen, the charging profile for Home tap the trash can icon to remove it.
idahospud
idahospud
Idaho
Ah, the source of the confusion becomes clear :) There is nothing to delete - those pages are not there to change. When I go to the page you are referring to, my data is gone - this is what i see.
Ford F-150 Lightning Updates and features not working correctly 1752510467083-ln
Confirm that it's also gone on the Sync "Charging" screen.
Then upon your next charging activity, build the new home location preferences for SOC & time limits is needed.
idahospud
idahospud
Idaho
Confirmed. I have already done through multiple charge cycles. The screen doesn't change. Can't add new stations.
I wonder if one of the recent updates some truck got over the past year has fouled up the "add new charging location" process, IIRC we had figured out a by pass for it ..... I forgot what it was and some folks couldn't get it to work ..... Might be you need to delete the VIN/VEHICLE profile from your FORD.COM account then start from scratch?
Need to research this issue again, if anyone out there remembers, please chime in!!!
Don't do this just yet ....... but
https://www.ford.com/myaccount/account-dashboard
Ford F-150 Lightning Updates and features not working correctly 1752542013958-ni
