Using F150, CSP and HIS to discharge to a DC load
Runaway Tractor
Yes
Then I'll plan to replace the board in the FCSP in order to communicate directly to the truck using proper hardware made for bidirectional charging.
And how exactly are you planning to "replace the board" with _________ to magically tell the truck to do what you want?
windydrew
Kansas
23 Lightning Lariat ER
Solar Installer/Electrician
Just got in touch with Wallbox and trying to get the Lightning tested for use with Quasar Bidirectional charger. Hopefully they're a much more affordable system compared to Delta/Sunrun
SpaceEVDriver
Arizona
I'm digging through the documentation of the HIS/Delta BDI, and as far as I can tell, this whole setup should be much simpler than SunRun has decided to make it.
The "RS-485" connection looks a lot like a 2-wire genset remote start/stop relay control common on almost all inverters with an automatic generator failover.
