Would installing a leveling kit void the warranty?
broteus7
Irvine, CA
2023 XLT ER Carbonized Gray Metallic
First time considering modding out a truck but I was thinking of getting the front raised. Would there be any issues with warranty? Would you recommend the dealer service center to do this since I would most likely need an alignment with it?
Whammy Bar
For it to void the warranty, it would have to be deemed responsible for the failure of that component. Its pretty unlikely an aluminum spacer is going to impact anything warranty related.
Get a quote at the dealer and at a shop like 4wheelparts and go with the one you feel the most comfortable with.
Granger Ford
Gold Sponsor
Zach
Granger, IA
www.grangerford.com
Principal at Granger Motors
He is correct. The Ford technician would have to say that the level kit is what caused the issue. It would have to be specifically because of that reason.
KevinTisdale1
Kevin
Brentwood, CA
F 150 Lightning Lariat
[/QUOTi had the dealer make that mod. Looks nice
LazyLightningATX
Doug
Austin
'23 Lariat ER
They did nearly 20K worth of warranty work replacing a bad HVB module on mine that was leveled week after I bought it...
Ishkatan
Adam
Monrovia, Md
2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
Old
It will likely affect the aerodynamics of the truck and reduce your range. When you take it in for range issues they may point to the lift as the cause.
