rjhedrich
Yes they did a complete analysis of my electrical box. They were all certified electrical companies and licensed in the state of Nevada. I also paid each a fee to do a complete including using a clamp on each breaker where I had to ramp everything up and each I contracted with said nope the max that can be added is a 60:amp which I had to give up a old rv plug that was set at 50 amp. For me to get the amps I needed my wife would have to give up her electric double ovens and her electric dryer. I would have the cost to run gas lines and by her new appliances .Did any of these contractors put an AMP meter on the panel and have you run 'all your stuff?' If not they are just guessing. You can do this yourself with a clamp meter for $20 from home depot. Pull the cover, put the clamp meter on one side, turn on the max stuff you think you might run and see what the usage is
