M.R.F.O.R.D.
2021 F150
What’s the NEW hitch view? I added hitch view to my APIM. Granted I can’t use at speed, but I can select it, where I didn’t have the option before.
I think is might be part of the ONBOARD SCALES (Link)
Load trailers easily
Class-exclusive Smart Hitch is designed to help customers easily load trailers and better practice safe towing. Smart Hitch measures the tongue weight of a trailer being connected, to help the customer distribute trailer weight correctly.
After the trailer is set up in the center touch screen, Smart Hitch calculates its tongue weight and provides guidance on weight distribution or hitch overloading on the screen, on the FordPass™ app or within the smart taillamps. The truck also will indicate if the hitch weight is too high or low and can even guide owners through properly tensioning a weight redistributing hitch.
Valleyrider
Fresno, CA
2021 F150
Hitch view should show it as if looking straight down on the hitch, not part of onboard scales as I don’t have ccd or the scales.
Ford F-150 Lightning 2021+ F-150 FORScan List / Database / Spreadsheet ? DF37E826-E0AA-4EE0-AA0B-A07E358BE511
Hivolt
Tukwila, WA
F150 Platinum 4x4 super crew, max tow, 400hp 302
Unfortunately, there isn't a way to get rid of the sidebar via the screen size settings... ?
Had some free time today so I played with a couple things. First of all, the DRL brightness mod 100% worked for me. Very cool!
I asked a couple times about changing my screen size to try and get rid of the sidebar and force everything full screen. I tried all the configurations, and none seemed to change anything, except for 09 - 13.3" Landscape (Qt based). That one changed my layout to the one from the Mach-E, squished on to the left side of the screen. ??
Interestingly enough, changing back to 03 (my default value) brought up the Mach-E screen again. To get back to normal, I had to switch to 00 (8" landscape) and then back to 03 to get my original screen back.
I think that X with arrows on the screen will make it full screen and get rid of the sidebar.
didiasku
Curt
Ohio
2021 F150 Lariat
thought I'd tinker a bit...I tried enabling the side mirror reverse tilt and now having issue
1) when selecting the left or right mirror while in reverse, they tilt down, but the left mirror keeps trying to pan down indefinitely while the right mirror tries to pan right indefinitely (clicking mirror noise)
2) so i thought ok, this isn't going to work, I changed back the APIM and IPC settings to the original (no tilt)
3) ive power cycled and now if I'm in reverse and select a mirror, it continues to do the erroneous behavior.
Not a huge issue as I have no reason to select a side mirror in reverse (without reverse tilt working) however, I am curious as to why configuring these 2 settings back to their defaults, the mirrors still operate as if "reverse tilt" is enabled.
thoughts/help?
Problem solved...had to enable reverse mirror tilt on APIM, go to settings, then mirror, then turn off reverse mirror tilt.
mhoffman54
Matt
Minneapolis
2021 F-150 XLT (302A), 2016 Harley Davidson Sports
Car Sales Consultant
The system works basically the same way noise canceling works, but rather than suppressing noise they are accentuating certain notes. Since each of the engines have a different “natural“ sound, there are differences in what needs to be suppressed and accentuated to create the V8 sound.
Using a different calibration will change how it sounds. You will have to experiment to see if it sounds better or worse.
Interesting! Now I want to play with it!
mhoffman54
Matt
Minneapolis
Only for nav. What I'd REALLY like to be able to make full screen is Android Auto.
tonesto7
Anthony
2021 Lariat 502A | 3.5L EB
IT Admin | Software Developer
You need to update the IPMA. FDRS Only cant be done with USB like other modules. Takes 4-8 hours. The update will allow for the IPMA to display in motion. The update will NOT allow the cargo cam to be full screen or to display on side card.
Thanks... You basically confirmed all my suspicions.
Do you know the calibration version required for the IPMA?
I recently updated mine with FRDS.
Code:
IPMA - Image Processing Module A
Part number: ML3T-14G647-FK
Calibration level: ML3T-14G647-FK
Strategy : ML3T-14H102-ACA
Calibration: ML3T-14H103-AAF
I'm pretty sure that once ford releases the next power-up for the APIM (post 1.7.1) that we will hopefully be able to use the cams in motion.
mhoffman54
Matt
Minneapolis
Code:
I have 2.1.0. No cams in motion.
Jesse-Infotainment
2024 F150 Lightning Platinum
Code:
Hi, I will try and get them off of mine but there has been a total of 2 IPMA updates. he first IPMA update resolved a clarity/Resolution issue with the camera system. The second was not specific to the camera in motion but that was included. Also if you have the latest update and still do not have motion you will need to adjust as built in the APIM as well. I used a 21.5 as a guide. You could maybe use the forscan dropdown style configuration also to adjust yours to remove the speed limits. I just found it easier the way I went with it since I knew the speed restrictions were resolved in those truck.
Unfortunately the IPMA will likely not get OTA for these updates as they are so large and can cause too many issues if they do not complete. Since the IPMA controls so much of the vehicle. It is one of the most important modules in the Truck. If you look at the operation charts for the 2021 almost all runs through it. If it were to fail during an update it would be a big problem for ford and this update is huge. I do understand a portion of the time required for the update is due to the Canbus data speed limitations but the update took me 6 hours or so on a 360 cam IPMA. Could be less for the rear cam.
My understanding(Could be wrong) The ethernet is only for OTA, the gateway downloads the update(8GB limit) and then transfers the update through ethernet to the module. Modules with Ethernet. APIM, TCU, IPMA(If Update is Small enough), Gateway(Some that have an early build that have not received OTAs as of now need to have the dealer manually update their Gateway as it was the issues causing OTAs to not work), IPC, B&O Amp. Again I could be wrong but its what I understand since the ethernet has a much higher data transfer speed.
I have received all the power up updates including the latest 2.1.1 and prior the 2.1.0 and neither address the IPMA. The 1.7 was an APIM update to 21146. I did that one manually though, I was to anxious to wait.
The 1.7 power up was to get the APIM to build 21146 for 21 builds. The 1.6 was a gateway update. I cant say what the prior one was. I believe it was a TCU(Telematic Module) update to improve responsiveness.
There are several updates available for early 21 builds that are dealer visit required. I would suggest to those of you that have not gone to a dealer or have FDRS access to log in and get all of those done and I believe that will help with those of you not receiving OTA. I am receiving OTAs and my truck is so far from stock its hilarious when I get in and see a successful update.
One Note to those with a APIM build previous to 21146. 21146 will not even show in FDRS until the Gateway update is completed, If you have a truck that has not received any updates I would suggest strongly you be the ones to go get your truck fully updated. A lot of the updates depend upon other updates being there.
Sorry if this is a bit of a rambling post, I just got on and am going freestyle. I am trying to help as best I can. I know it can be frustrating to not have updates others are getting but I really suggest you follow the advice I gave to get the updates done. I think once you do that you'll be ready to start receiving updates.
Also be careful when comparing to 21.5 trucks for as build date. They are different and some do not have the start stop they removed it so they can ship them faster.
Side note any of those with a July build that can not activate Fordpass you need to go to the dealer for a gateway reconfigure. There is a TSB/SSM/GSM about it.
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
Fantastic post.
Again, this is far more complex than the concept of OTA updates is in the average consumer's mind.
Zyvin
SC
2021 F150 Crew, FX4, Lariat
weird. My APIM software is now showing 21146 Rev 145, but it did not show that until the PU 2.1.0 update completed. Keep us posted, this is great info.
Jesse-Infotainment
One thing that this could be.. and it is so strange. I manually update APIMS on my bench. WHen I was first doing them the update would say complete and I would do the required restart to complete the update but the build would not change . I would think the APIM didnt take it even though it said it did. Well what happened I then did a longer ignition cycle and then the apim rebooted about 2-3 times and then it showed the update. It seems strange enough that the update sometimes does not show right away. It was frustrating on the bench. Until I kinda figured it out. So maybe just maybe the update had been completed in your truck previously but didnnt reflect until the next ota because the power cycle or something. Not stating as fact but just based off the things Ive seen in messing with them on my bench. I have seen one I did update not update supposedly only to next time I plugged it in a few days later to show updated.
The TSB that is about the APIM update says to leave the door open and leave the ignition off for ten minutes at min for the second part of the update to kick off. Again just a thought. 21146 is a update they released in conjunction with TSB 21-2310
Or they could have sent it out with 2.1.0 as well I just cant say for sure We would have to hear from others that pay attention to these things.. I just know that I recieved 2.1.0 and I had 21146 already it was released in October with the above TSB. I do know for sure though the Gateway has to be fully up to date for the 21146 update to be available. It is stated in the TSB. I can post it if that is allowed. I dont know what the rules are
Zyvin
SC
That sounds really plausible as my truck sits in the garage most of the time. I just happened to drive it today, and noticed the APIM software had updated. I theoretically could have 2 OTA updates go through and only cycled power in the truck once or twice.
Nightshade
Aidan
Alberta, Canada
'22 Ford F-150 Lariat | '22 Ford F-350 S/D Tremor
Sup/t. Wildland Firefighter with Alberta Wildfire
Code:
Can confirm the Ford Power-
I like how Ford is trying to be innovative with the Sync 4 OTAs but it’s getting annoying + frustrating when most people aren’t getting the up to date softwares. Even myself just got the 1.6.1 and the 1.4.0 and my other friend still hasn’t received it yet.. it’s crazy.
Jesse-Infotainment
I know it is frustrating. I am not going to defend them but it can happen. It is new to them. I would suggest you go get your truck fully updated at the dealer and I believe that would put you on track for the future updates. The gateway update has to be done. The gateway is THE most important module in this system for updates.
