JEB
- Aug 15, 2021
- Northern Illinois
- 2021 F-150 Lariat Powerboost
@Jesse-Infotainment gave me great guidance for unlocking cameras at speed. You need to use FORScan to make the following changes to the APIM, assuming you have the most recent updates.I finally got BlueCruise activated this morning but I noticed my cameras were not working at speed. I forgot I did change some settings a while back to active some at speed.
what is the best way to fix this now? I have my original values but am concerned that if the updates changed something I would be changing it back to the original values. Can I just download the As-Built to a job2 truck and make mine match or is there a better way to address this?
7D0-01-02 - AXXX-XXXX-XXXX
7D0-01-03 -X2XX-XXXX-XXXX
7D0-01-04 - XXXX-FXXX-XXXX
The second change might already have been made with the last round of updates. It was for me. I only needed to make the first and third changes. But the changes make a big difference. After the changes, you should have the same functionality as Job 2 and MY ‘22 trucks.
