Garage heater
Joel
New Hampshire
22 MachE. 23 LYRIQ on order its built
I some times in the winter use a friend 1 car garage that does not have heat. Could I use the trucks plugs to run a heater. Looking at lowes sie they list many garage heaters Your thoughts ideas
No reason you can't.
sotek2345
Engineering Manager
If your goal is to heat the garage, this will work fine. If you are trying to keep the garage heated to protect the battery or avoid range reduction, best to just leave it alone and left the truck take care of itself
If the garage has electricity, plug it in to shore power, not the truck.
Joel
New Hampshire
Amps
Bolt
It's a 7500 Watt heater, with a 6250 Watt low setting. It should work on the low setting only and probably will trip the truck's breaker on the 7500 Watt setting. As long as the heater does not default to the high setting every time you restart it, it should work. You'll be reducing your truck's range about ~15 mph of heater use.
Also, this is one of those things best used with short, heavy-duty extension cords (30 Amp Low setting), or none at all.
VTbuckeye
Vermont
Does not have electricity in the garage. I would like to to use his power with extension cords from his house for some heat. I use it for a couple hours
thinking something like this just not sure the truck can power it
https://www.lowes.com/pd/Comfort-Zone-Digital-Fan-Forced-Ceiling-Mount-Heater/5000235905
It looks like it could work. It looks like maximum draw is 7500 watts, which 31 amps. As long as you did not turn it up to the maximum output. You would have no power leftover for other uses.
beatle
Springfield, VA
I've heated up my semi-insulated attached garage with my Model S cabin heater on occasion. Turn it on full blast and open the car up. With the cabin heater being 6kw, it's not long before the garage is relatively comfortable - and I have a two bay garage. For a one bay you'd be comfy in no time.
7500 watts, /240v = ~31 amps, you would be exceeding the capacity of the 240 volt bed inverter, but the heaters MODE BUTTON has a low/full power setting.
Ford F-150 Lightning Garage heater 1651507072337
There you have it, 6250W mode would do the trick!!!
6250w / 240v = 26amps
Ford F-150 Lightning Garage heater 1651507139622
That’s a great idea. Eliminates both the need to buy a separate heater and incur inverter losses!
