Lightning Tire Pressures (Door vs. FordPass)
Mike G
N. AL, USA
Got the truck home and wanted to lower the tire pressures from what they get shipped as (happens everytime I get a new truck).
So I checked FordPass and noticed this:
Ford F-150 Lightning Lightning Tire Pressures (Door vs. FordPass) Lightning_tires_FP
Wow. they're really overinflated....
But just to be sure I checked the door...
Ford F-150 Lightning Lightning Tire Pressures (Door vs. FordPass) Lightning_tires_door
Hmm.. I guess they weren't that bad after all. ?
So I dropped the high ones down a couple of psi....
So don't believe FordPass...check the door sticker.
sotek2345
Engineering Manager
That is strange - I wonder if it is a carry over from the ICE pressure settings....
FlasherZ
St. Louis Metro
My experience with Tesla is that I get better range but a slightly firmer ride at door pressure + 2-3 PSI. Tesla wants 42, I run at 45 (tire max is 50 cold) - of course, air suspension helps to keep the ride good, so not sure I'll do that in a spring suspension.
Mach-E recommended pressure is 39, vs. 35 on most vehicles.
Don't check tire pressure after driving. Pressure is for cold tires. 44 is probably right on for a warm, but not hot tire that is supposed to be 42 cold.
Farmford42
WA
69 Bronco
Farmer
What did the truck display say about the tire pressure? Did that have the right information?
Theo1000
Theo
Shawnee, KS
Audi Etron,Chevy Volt,BMW I3,Mach-E,F150 Lightning
Most EV's do better with slightly higher tire pressures. They run quieter, corner better, accelarate faster and extend range. If it says 42 psi. I'll probably run my rears 44 psi and my front 46 psi.
Griddlez
Griddlez
Metro-East of St. Louis, MO
Yea I would believe the door sticker over food pass.. pretty sure a certification process has to go through for that door sticker to be produced.
Mike G
Mike G
N. AL, USA
It doesn’t say what the recommended pressures are just what each tire pressure is at that moment.
GunRack
Peter
Seattle, WA
22' Lighting XLT
What does the door tire pressure sticker say for the 18" wheels? Can someone post a picture?
SteffanG
Steffan
Langley, BC
2011 Audi Q5 (written off), 2008 F150 XLT HDPP
If anyone hasn't found out yet, that issue is the recall ford has on the Lightning. The 35psi was also the value for low tire pressure in the computer as well. The correct value is the 42psi
