Anyone having this issue? Front Trunk Outlet Cover Not Shut
parabellum85
Austin
2022 F150 Lightning
I keep getting this error and wondering if its a software issue or if I need to take in my truck. "Pro Power Onboard Lightning the front trunk outlet is not shut." The cover is shut but constantly getting this message.
duncanmaio
Duncan
Norwood, MA
I got the same message a couple of times, but the outlet cover was open. Closed it, and no more message.
SteffanG
Steffan
Langley, BC
2011 Audi Q5 (written off), 2008 F150 XLT HDPP
Did you try opening it and closing it again? Sometimes it is the simple things - might be a micro switch in there that got stuck or just on the edge of being closed.
Yes - have had it about 3 times in 10 days. Pushing on it confirmed it was already closed. They have a very finicky switch of some sort. I'm not sure why this is a critical item or message anyway, but they created it, so not sure what they aren't monitoring correctly.
FlasherZ
St. Louis Metro
I had it as well after showing someone the receptacles... an open and close and it stopped complaining.
LightningShow
MA
'22 Lariat ER
Product Development
Wow, what an incredibly annoying thing to put a switch on.
parabellum85
parabellum85
Austin
2022 F150 Lightning
Unfortunately I have tried that multiple times.
shaikhriz
rizwan
illinois
ford lighting
yes happened to me many times
MRButtler
Matt
2022 Lariat Lightning
Touch a magnet to the bottom of the outlet, flip the magnet and touch again. Try the cover now.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
RGC
Ric
Ford Lightning Model Y
Yes I had same problem. After a couple months it went away after using outlet a couple times.
BuzzLightning2023
Los Angeles
92 Explorer,94 F150,06 Avalanche,05 F250,11 F150
Mine is at the dealership since 6/26/24 after having a drivetrain malfunction and high voltage battery warning. It’s throwing 2 error codes related to the TCM. Looks like they were test driving it 7/3/24 and I was getting “messages” on Ford Pass that the Pro Onboard Power and Frunk outlet cover were acting up. They’re no closer to diagnosing any of it and new concerns are dropping like dominoes now…
Mike G
N. AL, USA
They haven't connected FDRS up to it yet...but you did get an OTA the other day for the gateway module ( Ford Power-Up 4.2.3.1 ).
Here's what your truck told the cloud yesterday:
Ford F-150 Lightning Anyone having this issue?  Front Trunk Outlet Cover Not Shut 1FTVW1EL6PWG38774-4-Jul-24-VHA
Maybe they ought to just give up and update your OBCC to make that DTC go away....just sayin'.
BuzzLightning2023
Los Angeles
I think this might be the truck I reserved but didn’t buy. I’d love to see this for my truck, tho. How do I access this info? Thank you.
