Blue charging indicator light change?
blpublic
Missouri
2016 F150 XLT
Has anyone noticed that their charging indicator light no longer turns blue to show progress? Or, maybe this is only with certain chargers. The picture below is shown charging with the portable charger with 240v.
Ford F-150 Lightning Blue charging indicator light change? 68B51102-A2AE-4AEC-9E67-C2F5D17D8C36
or, it may also be that this indicator light only stays on for a few minutes... doesn't mean it's not charging, but the light is an 'owner' indicator.
I wonder if pressing it will reactivate it.
Beans
Phil
Beaver Dam, WI
Acura RDX, Toyota 4 Runner
Mine still works the same. Blue when charging, flashing the percent quarter that it's current charging in.
Nickbommer
Nick
Lightning xlt ordered
Can someone tell me what exactly that button does? I thought i would press it and it would unlock the charger but it doesnt. I held it and it still doesnt.. not sure what i am doing wrong.
On my Mach-E, it is used to stop a DCFC session. Then the CCS connector can be removed by pressing the latch on the connector. When I first got the car, I couldn’t unplug my L2 cable unless I pressed this button first, but that apparently got changed by an update.
Firestop
Firestop
Isn't there a setting to turn it off? Maybe you toggled it.
@blpublic
Yes, it is buried in the “Vehicle Access” screen of the vehicle’s settings ….not the most intuitive location to put it, and the location of this toggle is not explicitly identified in the Owner’s Manual …..just a general reference to “Vehicle Settings“…just not where in those settings……
Ford F-150 Lightning Blue charging indicator light change? 742CB57D-118C-482D-B6CC-9BD1E8AB28B8
Ford F-150 Lightning Blue charging indicator light change? 150FCD68-DEFD-4381-A7E1-37954B2F9C03
Ford F-150 Lightning Blue charging indicator light change? 0CD99817-74A1-4D52-BD7A-75F0AA9E88F7
Firestop
Firestop
It appears to be the same with the Lightning…the Owners Manual instructions for disconnecting from a “Charge Station” and a DC Charger differ in the instructions for disconnecting from a DC charger explicitly state to first “push the coupler unlock button”.
Ford F-150 Lightning Blue charging indicator light change? 4DEFC074-7D14-4D14-BDFA-071DCEB467C5
Ford F-150 Lightning Blue charging indicator light change? 1E257C41-7978-4E3C-814B-CCB8C0724C16
Ford F-150 Lightning Blue charging indicator light change? AE1194BF-CD6E-43DA-9A06-AE3A897CCB25
Ford F-150 Lightning Blue charging indicator light change? D9754581-EBEB-4981-BA24-19E1908DF676
Amps
Bolt
They put so much effort into the charging port light, it's a shame you don't get more details inside the cabin while it's charging. It's not the only EV like this.
blpublic
Missouri
2016 F150 XLT
Agreed! We can't tell what is limiting charging or even the charge rate. Many people can't see or even know how to see the rate on the charge station itself. We have had a really bad experience with slow charging in Missouri along I-170. The Electrify America in Boonvill rated at 350KW only charges at about 64kW consistently. There are no other 150kW+ chargers between St. Lous and Kansas City. When you tow, we need 150kW charging to make it reasonable and slow/broken charging is killing us. I'll post more in the trip section.
blpublic
Missouri
2016 F150 XLT
@blpublic
Thank you! A classic case of RTFM - sorry. I didn't know my dad had accidentally changed this.
vandy1981
Tennessee
Plumber
I still think the charging ring on the Fusion/C-Max Energi was the peak in charging indicator light design. I also liked the door swiveled out (similar to how Rivian is doing it).
Ford F-150 Lightning Blue charging indicator light change? 1659555614745
Ford F-150 Lightning Blue charging indicator light change? 1659555660026
Firestop
Firestop
No worries….I stumbled across the location of this setting when rooting around the UI on my 2nd day. Had I just read the manual, I would have still had to root around because Ford didn’t make it clear in the manual were this setting is located! “Vehicle Access”….the Frunk is shown at the top of the screen and the rest of the controls are related to charging. ?
