(WTF) No Drain Plug in Mega Power Frunk!?
T i h o r
Rohit
Toronto
Self Employed
I met up with some buddies last weekend and was excited to put the sub compartment in the Mega Power Frunk to good use.
Ford F-150 Lightning (WTF) No Drain Plug in Mega Power Frunk!? 20220807_090312
Loaded it up with a few drinks and ice since we'd be hanging out in the blistering heat & crazy humidity - only to get to my destination and realize all the ice melted and drained away. It then dawned on me that there's no plug for this drain. WTF ?
Ford F-150 Lightning (WTF) No Drain Plug in Mega Power Frunk!? 613a272e2534ab0018537c91
Anyone have a solution? This is honestly such a crippling oversight. It's like the engineers that were responsible for adding this feature, never actually used a cooler before. lol
cag
Cole
Seattle
2014 Ford Fusion
Police Dispatcher
Yeah its gotta be intentional.
1. Idiot puts ice in frunk.
2. Frunk gets couple inches of water.
3. Idiot starts car and takes a turn.
4. ?????
5. Water into outlet
broncoaz
Cape Cod, MA
I don’t know what’s under the frunk, but adding a drain plug to plastic should be straight forward.
theblunden
NC
2023 F150 Lightning XLT
I'm more concerned about your drink and snack choices than how they idiot proofed the front trunk.
T i h o r
T i h o r
Rohit
Toronto
Self Employed
Hahaha I knew it was only a matter of time before someone called that out!
My buddies and I all have GT4/Spyder's, so we planned a group buy & install of new air filters. I knew we'd be hot as hell working on the cars outside, so I grabbed mostly water and Gatorade.
Ford F-150 Lightning (WTF) No Drain Plug in Mega Power Frunk!? IMG-20220807-WA0154
For the record, there was a 24 of Corona cans mixed in there as well! lol
theblunden
NC
You could probably block the drain hole with a piece of plastic and yank the thing out to drain
It's not a cooler. Ice melts very fast. Pretty clear there is no plug.
T i h o r
T i h o r
Rohit
Toronto
Self Employed
How long did it take for the ICE to melt?
I'd say less than an hour! My 2nd gen Ridgeline had the same feature, but had a drain plug so it lasted much longer.
T i h o r
T i h o r
Rohit
Toronto
Self Employed
Yep, the solution is right there with the ice bag. It will probably weep enough water to avoid the frunk as a bathtub.
I tried that as well, but there isn't a tight seal, so the water still leaked/drained.
Ideally, I think if we could 3D print a plug, that would solve the problem! ??
gpbst3
PA
f150
I guess Ford assumed if you can afford a Lightening you can afford a cooler.
Has the frunk ever been advertised as a cooler? I would not believe it to be insulated and to my knowledge electric motors still generate heat.
