Launching the Lightning (for maximum acceleration) - can it cause damage?
CRAIGC540
Craig
Moreno valley
Technician
I see videos of people launching the lightning brake pedal down, accelerater down break pedal up to launch. My question is can this damage the lightning in anyway?
theblunden
NC
2023 F150 Lightning XLT
I've heard you have to put it in one pedal drive and push the accelerator and let off the pedal at the same time ?
sotek2345
Engineering Manager
If torque is instantaneous on an electric motor, why “rev” to launch?
You gain a split second because you an come off of the brakes faster than you can get to the accelerator pedal all of the way down.
cvalue13
Austin, Texas
‘22 Lightning ER Lariat
Fun-Employed
I’ve never heard of any actual launch sequence for the lightening.
In a BEV, I’d expect a true “launch sequence” to reduce down to nothing more than software settings, that eg adjust traction control and - perhaps - synthetically “view” the peddle to be fully depressed upon the most initial touch of the peddle.
accordingly, makes zero sense to me that instead treating the BEV like an ICE does anything meaningful for “launching“ the Lightning - as it surely doesn’t initiate any software changes, and unlike an ICE there’s almost no use to depressing the break while pressing the throttle (there be no apparent rev, gearing, or other consequences in a BEV)
cvalue13
Austin, Texas
Fun-Employed
this would seem to assume the trucks software doesn’t negate the intended effect.?
possible,i guess - but still nothing like a true “launch sequence”
CRAIGC540
CRAIGC540
Craig
Moreno valley
Technician
My concern is damaging internal components.
In videos you can see the rear set down because the truck is being held back by the brake. This method seems to launce faster opposed to just slamming the accelerater. I have test driven 3 Lightnings and it's quick enough. Mine is close to delivery and wanted to try this method but not if there's a chance of damage.
sotek2345
Engineering Manager
Would I do it every day? No - every once in a while should be fine. Kind of like revving and dumping the clutch to launch a manual transmission vehicle. Just don't do it at every stop light!
CRAIGC540
CRAIGC540
Craig
Moreno valley
Technician
Yeah I will probably try it once to see the difference.
cvalue13
Austin, Texas
Fun-Employed
Interested to hear a report, especially with any data
I don’t instinctively see or understand how I’m earth this is effective, even incrementally: maybe y’all’s legs work differently than mine, but I don’t the latter of these two things being quicker
• single right leg resting on full open throttle peddle slams to floor
vs
• left leg holds down break peddle to floor, and pulls back simultaneously with; right leg holds throttle peddle at 1/2 (? 1/3?) and slams to floor
‘cause again, there is no “rev” to achieve, or gearing to quicken towards, here - the difference would be merely the reaction time needed to get the throttle peddle to the floor - and I don’t see involving my left leg/break release as obviously decreasing that timing
Meanwhile, I’ll continue just spamming @Ford Motor Company to OTA release a launch sequence so that we might finally see how the Lightning compares to the Rivian
sotek2345
Engineering Manager
vs
A couple differences from your thinking
1) start with the accelerator all of the way down
2) You don't need to come fully off of the brake - as soon as you release enough to move the pads away from the rotors, the truck instantly jumps forward.
In the real world this is largely meaningless - when using something like a draggy to get 0-60 times, or at a dragstrip, it can make a minor difference.
cvalue13
Austin, Texas
Fun-Employed
I’d be interested to see if this can be held, by anything other than software
in which case the software itself may not at all be providing the type of “mechanical” release that is being assumed
suppose I could get anecdotal and grab my keys…
sotek2345
Engineering Manager
Anecdotal from our MME-GT, it makes a small, but noticeable, difference.
GarageMahal
JT
Data Wrangler
There is also benefit from loading up the suspension (i.e. the squat) by holding the brake.
