Discrepancy between electricity going in and battery
antimatterparticle
Higgs boson
PA
Y,150,4XE
So I have noticed that my EV juice box shows a higher amount of energy added than what the Ford App shows.
why would this happen?
Ford F-150 Lightning Discrepancy between electricity going in and battery 59E7DB02-A54B-442D-856F-F532C3B2E003
Ford F-150 Lightning Discrepancy between electricity going in and battery C1A054C5-CAF7-4DE4-9110-AF880E991F04
update: in this charging session the final results are
71 in
64 charged
Which seems to be in line with the 10% mentioned here.
I am wondering if the 80amp Ford Charger is more efficient. (Wiring, less time to charge=less heat created etc). Can you track how much energy goes in with the Ford charger like the Juicenet?
but if this is the norm, people should be adding an additional 10% to the cost of operation.
trev5150
Banned
Banned
Banned
Trev
Pilot of pilotless things
Stupid thermodynamics....
GarageMahal
JT
Data Wrangler
vandy1981
Tennessee
Plumber
The JuiceBox is measuring kWh delivered to the truck from the JuiceBox, which includes energy lost to heat and operation of the coolant loops and inverters. The truck is only reporting the energy that's added to the battery pack. Also, I would not trust the Ford app to give you accurate real-time or logged charging session data--it's been unreliable in my experience.
You should expect to lose around 12-15% between the EVSE and battery with level 2 AC charging. Losses should be below 5% with level 3 DC fast charging.
Akbrian
Alaska
F150 Lightning 2022
Put in 3.78 and got 2. That’s no where close to 10-15%. Loss.
There’s overhead involved initiating a charge. Short sessions always look worse. Notice that by the time the session completes, the losses are in line with expectations.
Another problem with small numbers is that the Ford side is rounded. 2 could be 2.4. Maybe even truncated from 2.9?
adoublee
Midwest
2 EVs
"update: in this charging session the final results are 71 in 64 charged". That is 10%, and better data than going off of readings at 2kWh of charging to the whole number kWh precision.
Also helps to know accuracy of metering.
antimatterparticle
Higgs boson
PA
Y,150,4XE
the issue is that on a 131kwh battery 10% loss tends to add up.
i may have not noticed it before with other EVs because the battery pack is much smaller.
Also I can barely get 260 miles. I’ll have to wait a couple of months and see if it becomes too much of a pig…
Going into winter, 260 is likely your high water mark. Expect to see 200, maybe less if you see sub-zero temps. It will come back up next summer.
That's good, I've been observing around 11% losses.
