Installed JL Audio 8" Powered MicroSub+ behind rear seat - Lariat ER
skyak
F250, 911, Lightning
Transforms the audio experience and doesn't interfere with under seat storage. Replaces the stock subwoofer. Power fed from 12v battery. It really is amazing bang for buck. The sub output level control is installed on the steering wheel column. I highly recommend this solution to anyone wanting to improve the audio experience with minimal work.
Ford F-150 Lightning Installed JL Audio 8" Powered MicroSub+ behind rear seat - Lariat ER 1670726848095
Ford F-150 Lightning Installed JL Audio 8" Powered MicroSub+ behind rear seat - Lariat ER 1670726891164
Will your rear seat lock in the up position with it installed?
skyak
vagabond7846
NJ
Looks nice.
Can you describe how you routed the power cable from the 12v battery to the backseats?
Also, did you ground on the chassis?
What was your stock stereo setup; regular B&O or unleashed?
skyak
Hi, stock stereo was regular B&O. I had a shop install it, so not sure on the exact routing and grounding, but I can take a look.
skyak
Looks nice.
I checked on the grounding, it is connected to one of the studs that protrudes through the cab floor under the sub location.
Also, the inputs to the sub are set-up for high-level (the sub accepts low-level or high-level), I assume it is using the existing wiring that was going to the B&O sub.
Ford F-150 Lightning Installed JL Audio 8" Powered MicroSub+ behind rear seat - Lariat ER IMG_3121
Ford F-150 Lightning Installed JL Audio 8" Powered MicroSub+ behind rear seat - Lariat ER httpswww.sonicelectronix.comlandingmanualsacp108lgw3v3-manual.pdf
SoundsGoodStereo
Gold Sponsor
Don
Mount Juliet, TN
soundsgoodstereo.com
F-150
Looks nice.
You want to run any aftermarket electronics ground to the battery, not on the chassis. While it might work, you're asking for trouble due to the high-resistance of the factory cab. These newer vehicles are basically glued together and do not offer a low enough resistance for sensitive aftermarket electronics.
vagabond7846
NJ
It has been a while since I've installed car audio electronics, but I used to just run the power cable to the amp from the battery, and ground to the body. To be clear; you are saying I should run two cables to the battery?
Since the truck doesn't have an alternator, there must be a voltage-to-voltage converter somewhere that charges the 12v battery -- Does anyone have information on how much current we can pull before it starts over stressing the converter and/or the battery? I'm trying to understand how big of an amp I can use.
thanks,
SoundsGoodStereo
Gold Sponsor
Don
Mount Juliet, TN
F-150
thanks,
Yes, power + ground to the 12v battery. The only reason to ground to the cab before was to save $$$$on copper wiring, just like the factory does. But until our aftermarket manufacturers offer a higher level of tolerance on the ground resistance, never assume you can have a good ground anymore except for the battery.
Regarding the converter, assume 100a which should be plenty of reserve for several thousand-watt stereo upgrades.
I was doing some research, and I was wondering if you saw this JL Audio sealed 10" powered sub, which has almost the same dimentions, and why you wouldn't have gone with it? There is a guy on the Mach=-E forum that loves this sub in his car, and I was thinking about putting one in both our Mach-E and Lightning.
https://www.crutchfield.com/p_13693334/JL-Audio-ACS110LG-TW1.html
Ford F-150 Lightning Installed JL Audio 8" Powered MicroSub+ behind rear seat - Lariat ER Captur
Ford F-150 Lightning Installed JL Audio 8" Powered MicroSub+ behind rear seat - Lariat ER Capture2
BennyTheBeaver
I'm also considering the MicroSub option. My initial thoughts is the power draw difference, that would lead me to lean towards the 8". The 10" might also be overpowering...
With the dial adjustment, I would rather have too much than not enough. It can always be turned down.
BennyTheBeaver
Wouldn't it have a higher RMS wattage though? Maybe I'm just hyperparanoid about the LVB with all the issues people seem to have with the LVB system.
