Why does my charger do this?
neririn
Usa
F150 MachE
About every 2-3 weeks, my charger will end up in this state. It will not charge until I unplug, and replug. However, that is all it takes to 'reset' it. It just started doing this maybe 2 months ago. Has anyone seen this?
Ford F-150 Lightning Why does my charger do this? IMG_2354
mstriker513
Cincinnati
I have seen this once or twice, also in the last month or 2, but I am not sure what the cause was. I just joined this group last night and I will reply back if I hear or figure out what the cause of this is.
Ford Motor Company
Official Ford Account
F-150 Lightning
Hi there, I'd be happy to look into your Lightning concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
The amber light usually means it has detected an overheat condition. In most cases, it’s a false error and the charger needs replaced. It should be warranty, but some have reported that their dealer won’t honor itt.
Pod
2023 AMB Lightning XLT SR
What is a good back-up mobile charger like this Ford one? Has to be a cheaper alternative. Would like it to have 110 plug as well.
tcfila
St Louis
2022 Lariat ER
Mine does the same thing when its really cold out.
Tim
AZT9
Peoria, AZ
I had to have mine replaced at the dealer last month. It lasted about 5-6 months before it would constantly de-rate the charge due to “temp”
PA Lightning
Tbone
PA
2025 Flash, 2022 Lightning Pro(traded)
When I got the mobile charger, I read the instructions and noted that it said to not let the charger hang from the outlet.
I see your charger is not mounted and is hanging. Could be as simple as that.
