F150 Lightning FORscan thread
Blochead21
PA
Black 22 XLT 311pkg
Sweet. Just bought the sensor and will install once it gets here.
BennyTheBeaver
Decided to take a second look and pulled the whole cover off. My 22 Pro does have the wire there, it was just tucked up there nicely. $40 auto wipers, here we come!
Thank you for the confirmation. Bought the part for my MY23 Pro.
Priccijr
Pete
RI - USA
2022 F150 Lariat Iced Blue
I ordered mine. I'll get it tomorrow from the dealer will try the install Wednesday.
Are we doing the four line change or the three in Forscan i saw some debate? Also how many clips holding the cover on the mirror?
Priccijr
Pete
RI - USA
installed. Seems to be working I will update after a rainy day. I’ve attached more pics. Of location, The tool I used, where clips are located on the back of the cover and the option to enable on the infotainment. I changed all four lines in Forscan.
Ford F-150 Lightning F150 Lightning FORscan thread 5F5F2B60-EAD0-4FC4-A66E-BA418F2F6BE5
Ford F-150 Lightning F150 Lightning FORscan thread 4C0CB4E2-2128-4707-9F54-2F00891416F5
Ford F-150 Lightning F150 Lightning FORscan thread 6699E91A-3B6B-48C9-AE2D-942E26B9AAD1
Ford F-150 Lightning F150 Lightning FORscan thread 5344BEF1-E822-40F2-87F1-9FB0439F956E
jimfigler
Orchard park, NY
good job! Ordered mine yesterday
Priccijr
Pete
RI - USA
Light rain today and sensor worked.
wighty
NY
Do you need to leave the wiper stalk in one of the 'active' positions? After the sensor doesn't detect rain for a while, do the wipers get parked (where they go lower than the 'at the ready' position with typical intermittent wiper settings)?
Priccijr
Pete
RI - USA
My stalk was on the first setting the single rain drop. After a little time of no use they drop down lower.
BennyTheBeaver
I installed the part today. On my MY23 Pro the cable was plugged into the area circled in the attached photo. I thought I was going to snap the plastic getting the cover off, scary.
Ford F-150 Lightning F150 Lightning FORscan thread 20230210_151741
Ford F-150 Lightning F150 Lightning FORscan thread 20230210_151832
BennyTheBeaver
its with all four changes i mention in my earlier post. so if one of those is BCM, then yes.
Add rain sensor:
7D0-09-04 x3xx-xxxx-xx—
726-39-02. xxxx-xxxx-01—
720-02-02. xx8x-xx—
724-02-01 xxxx-xC4x- —
part was
LU5Z-17D547-B
i cannot remember if it got substituted after my order for a newer part.
as i recall you just pull the cover down and it eventually unclips.
Those selections are in the AS BUILT sections BCM (BdyCM), SCCM, APIM, and IPC for anyone wondering.
BennyTheBeaver
Add rain sensor:
720-02-02. xx8x-xx—
part was
LU5Z-17D547-B
Could you verify that your 724-02-01 line is correct? I pulled up the spreadsheet and that isn't an option. One option is xxxx-x*xx and the other is xxxx-xx**. Thank you!
