Dead screen . 22 Lariat 6k miles
ragj1976
Have the dead center screen started today. Same symptoms as all others, startup animation works, then dead. Volume works. Rear camera works. Track/station on steering wheel doesn’t . But volume does.
Ford dealer can’t see it for 2 weeks :(.
Tried to remove 12 volt for 15 minutes. No luck.
ragj1976
Anyone know of a fuse, or a plug under the front seat to the seat heaters? They are on high and I cannot turn them off because the screen is dead.. There is a 40 amp fuse for front seat stuff in the front, but I don't want to pull that, it seems like it would be for other things also. There are a ton of plugs under the drivers seat.
Reboot Sync, hold volume down and right seek for 10 seconds.
ragj1976
Where is the APIM module in this vehicle? Behind Large Screen?
ragj1976
If I set departure time, cabin temperature to OFF. will that turn off the heated seat and steering wheel?
I should, but if you resume using the remote start it'll turn on the seat heaters at a later time.
Ford F-150 Lightning Dead screen . 22 Lariat 6k miles 1676416181530
Ford F-150 Lightning Dead screen . 22 Lariat 6k miles 1676416271738
ragj1976
Pullled that 40 amp drivers seat module fuse. The seat heaters still remain on lol!
Got to be getting fed from somewhere else. Crazy
Sorry that didn't work.
MJDore
SE Michigan
2023 Lightning Lariat ER
Finance
Fuse 32 on passenger side fuse panel is the one I pull when I get the unresponsive modem issue. It’s described as radio central gateway in the manual.
Ford F-150 Lightning Dead screen . 22 Lariat 6k miles F7D45BB5-CD55-4E57-B436-2B38013CC530
Ford F-150 Lightning Dead screen . 22 Lariat 6k miles 380DC7BA-BC81-4062-A8FE-66B94AA40852
ragj1976
Anyone know the under seat plug for the TED module in these trucks?
JC688
BMW X5, Honda Odyssey, BMW M3, Porsche GT3, 911…..
Happened to me. But mine went completely dead, no animation screen, no backup camera, nothing. Restarted the car and still nothing. After driving and letting it parked at the gym, everything went back to normal when I left the gym.
ragj1976
Update on this. Was able to get the truck into another dealer earlier. Said it was the APIM Module. They were supposed to have some in on the 17th but they haven't seen them yet. Going to have them keep the truck for a couple days to see if it comes in. If not get the truck back and wait is our only option.
