F150 Lightning FORscan thread
nauticalx
f150
Hi, I'm looking to activate the lights on OEM lightning running boards added onto a PRO without tow technology package using the factory pigtail near the rear wheels. Anyone know how to activate this? Thanks!
Learch74
Cory
New Brunswick Canada
2021 Mustang Mach-E California Route 1 edition
Network Engineer
I just set the new circumference and it worked you have to ask the folks at forscan for the beta version. It works in plain language not hex codes.
wighty
NY
Separately, I noticed in the "easy" mode for APIM there's an option for "Walk Away Lock" - has anyone messed with this yet? It's the number one thing I'm missing from my Mach-E.
I think that may require the door handles to be replaced, I assume it is going to be using some proximity sensor for the key... similar to approach unlock.
If you have an iPhone, here is a process I worked out. Ability to add delay and be location-specific. Has worked flawlessly for months.
vsansal
Volkan
Arlington,VA
F150 Lightning Pro, Tesla Model Y Performance
Another successful rain sensor install here. Was pretty simple on my 22 Pro. Once the option was enabled, I have set to setting one on the wiper stalk and it swiped once and then went back to standby mode. Will test it when it rains but looks good so far.
wighty
NY
What is the actual difference between the regular rain stalk and the automatic rain sensor one? Does it have the same number of notches, and the major change is just the picture labeling?
nauticalx
f150
did you guys have to do anything special after adding code for auto wipers and installing the rain sensor? just added it and it's not working. just wipes intermittent as before.
jallen
2009 F150 XLT / 2023 Ford Lightning Pro
Ok, nauticalx seems to be another one of us Pro owners that can’t get this to work. Trying to narrow this down.
Is there anyone in here who has gotten this to work WITHOUT tow tech or max tow? I have Pro power only and naiticalx has no options.
Thanks again everyone!
nauticalx
f150
I'm having the same problem as jallen not getting the rain sensing to work on a base pro.
Can someone do me a favor and check the voltage between the pins at each end of the 3 pin connector at the rain sensor? And what polarity they have?
The connector is numbered:
1) black wire
2) blue wire
3) green wire
Thanks!
Thanks!
Jasontn316
Jason
Tennessee
Sorry if I missed it in this long thread, but should the wiper wipe one time on each start if leaving at the single drop after enabling the rain sensor?
Mine did it occasionally, but not every time. So now I just turn it off since rain is infrequent. If it starts raining I turn it on -figured I’m not that lazy!
I'm guessing this is just bad software and control from Ford. I have a Lariat, so I have the sensing wipers built in and mine do this on occasion. Truly I turn my sensing wipers off on the stalk if it isn't rainy out just to prevent this. When rainy I turn them to auto and let them do their thing, they are pretty good at it. When sunny, I turn them off.
jimfigler
Orchard park, NY
Mine does not wipe one time at every start. I leave it in position one all the time.
