Efficiency at 70 vs. 75 vs. 80 on highway?
sotek2345
Engineering Manager
Thanks, I hadn't even thought about how rain affects range! Does anyone have any data or real world experience?
Based on real world experience, just raining is 5% to 10% range loss. Once you get to heavy rain or significant water on the roadway it can get closer to 20%. Based on my experience to date. Takes energy to push through the water.
LightningShow
MA
'22 Lariat ER
Product Development
But hopefully you aren't driving 85 mph with standing water on the road, so heavy rain actually increases your efficiency. ?
ETA: After having the Lightning for 7 months I can say I definitely drive *faster* in the Lightning than any vehicle I've ever owned. It's so quiet at high speed. It makes it very easy to cruise at high speed. Even so, my warm weather efficiency was 2.3-2.4 through the summer/fall and 1.8 since the beginning of the winter. The worst efficiency I've experienced on a longer trip was 1.5mi/kWh when I was up hiking last weekend. I started the morning at 5 degrees (preconditioned) and left the mountain at 10 degrees (with driving wind and snow the entire day). The trip up to mountain was around 1.4 and return was 1.6. Total 190ish miles using 94% of battery, virtually 100% expressway. I would consider this just about the worst case scenario and I was still seeing 1.5 for the trip. I can live with that.
NeilO
Neil
San Jose
F-150
On a road trip, it's faster to drive fast and charge more. The reality is you almost never go 80mph straight out for hours. I drive 80 all the time on my commute to work but occasional slowdowns and the 25% portion of the trip on surface roads means my efficiency for the trip is 2.5mi/kwh despite driving 75-85mph whenever the conditions allow it. IMO it has to be damn near impossible to get under 2 mi/kwh when you average out all of your driving unless you live and work 100 yds from the expressway and there is absolutely no traffic where you live. (ETA: Assuming good weather conditions, lots of HVAC use will knock you down lower)
I went on a roadtrip last week and I left at 5am in both directions so I could knock out as much as possible without traffic. I was driving 78-80 almost the entire first leg of each trip (150-200mi) and I still ended with 1.9mpk going south and 2.0mpk going north.
Agree with you completely. I just started thinking about it myself. Just because I can drive 80 mph doesn't mean my average speed will be that high. There are usually a lot of slowdowns during a trip.
Txxthie
Robert
CT
2022 TM3 RWD LFP
If you are not worried about running out of juice on a long leg of a trip, just drive 80 and don’t look at the numbers. Even if you get 1.8 mi/Kwh instead of 2, it is still a lot cheaper than gas charging at home.
Depends upon where you live.?
Figuring out an EV’s energy costs is a lot more complex than doing the same for a gas-powered car. But the Department of Energy’s Alternative Fuels Data Center has an easy-to-use calculator at afdc.energy.gov/calc.
And it helps to keep a few general principles in mind. For example, if you live somewhere with high gas prices and low electricity costs, such as the West Coast, an EV will almost always be less expensive to run than a conventional car or hybrid. But in New England, where gas prices are lower and electricity prices are generally higher than out West, those savings may be negligible and tilt the balance in favor of a gas-electric hybrid with a less-expensive purchase price.
Per Consumer Reports:
Ford F-150 Lightning Efficiency at 70 vs. 75 vs. 80 on highway? 0457EDA5-38DA-43FA-8D7F-A20C4E878B1D
Ford F-150 Lightning Efficiency at 70 vs. 75 vs. 80 on highway? 9D9213EF-EA51-4E67-850D-A268EF85E6FF
azypather
Azy
Navarre, FL
2017 Merc GLe 350, 2018 VW Golf SE, 2023 F150 - L
IT Consultant
So I took my first long, well "longish" trip with the truck. 70 Miles round trip (Navarre, FL to Pensacola, FL and back). About 90% interstate. Temperature was around 70F with light intermittent rain and gusty winds. On the interstate I averaged 75 - 85 mph. 30ish mph on local roads
Here are my observations. When I left home, my range was 175 miles. By the time I returned, the range was 75 miles. So, it seems like I consumed 100 miles of range on a 70 mile trip, driving as I would normally drive an ICE vehicle. On both the outbound and inbound trips, i achieved 1.9 mpkwh, which I've read is not terrible. I typically get between 3-3.3 on my local running around. This tells me that on a full charge (221 miles for me) I would only get about 140-150 miles of range driving the way I do. I'm perfectly fine with that...I have an ICE vehicle for road trips. But just thought I should share for anyone interested.
But man, what a truck! I am so impressed with the ride, the comfort, the driving position. The acceleration brings a huge grin every time, be it from standstill or 70 mph!
jplaplante
Seattle, WA
2023 Lightning XLT; 2023 Durango; 2018 Leaf
All of the advertised numbers are best case clearly. I just did my first big trip in my XLT SR across i90 in Washington. The Ford app calculated my first stop at 15 minutes in Ellensburg for a fast charge. That experience took nearly 1 hour between my wait for a charger, and the fact that 2 of the 4 chargers were unreliable or not working. Then my 150 kW charge quickly dropped to 90 and then dropped to 45 kW about half way through my charge. I picked up my pace to 80 ish MPH and saw my efficiency drop a lot. Subsequent to that I had to stop several times and spent a lot of time trying to find a charger and then charging. My takeaway - fewer charges is better. We have a long way to go before the charging infrastructure is not a cluster
mr.Magoo
2022 Lariat ER, AMB
Here's a quick test I did this morning as I had some tinkering to do anyway...
65mph = 2.2 m/kW
75mph = 2.0 m/kW
80mph = 1.7 m/kW
It's not scientific by any means as each run is in opposing directions and as such not accounting for elevation changes , wind direction, etc. but that stretch is relatively flat and there was hardly any wind this morning so...
This run was with the Ford 22" (non aero) wheels, but ironically, another trip that I logged on the same section (different day so obviously different circumstances, but it wasn't raining) with the stock Lariat wheels, registered 1.9 m/kW @ 75mph so I'm kind of surprised / pleased the change didn't make it much worse.
[EDIT] Added a 80mph comparison as well.
Ford F-150 Lightning Efficiency at 70 vs. 75 vs. 80 on highway? 65mph
Ford F-150 Lightning Efficiency at 70 vs. 75 vs. 80 on highway? 75mph
Ford F-150 Lightning Efficiency at 70 vs. 75 vs. 80 on highway? 1685985191204
65mph = 2.2 m/kW
75mph = 2.0 m/kW
The only way you know that, as you know, is to test it scientifically. People have registered a 10% loss with non-aero wheels.
Question - how did you measure speed? If you changed the circumference of the tire, but the setting in the vehicle still has the old tires, then your speed is off.
mr.Magoo
2022 Lariat ER, AMB
Most people with non aero wheels are using "off road" tires with aggressive thread patterns so I don't think one can make a general statement that non-aero means a 10% loss, now, I'm not saying that it won't be a loss, it definitely will be, simply from non-aero and the fact that the 22's are 17lbs heavier (92 vs. 75 as measured on a scale) than the stock rims/wheels.
How much is hard to quantify and depends on a lot of factors, I was just happy / surprised it stayed roughly on par in my highly non scientific comparison and wasn't the "automatic" 10% loss.
I have other measurements just the day before I swapped tires that shows 2.1-2.2 m/kW @ 74mph on the OEM wheels, but those runs where too short and on a different stretch of road to be a "direct comparison".
The speed in the graph is vehicle speed as registered on the gauge cluster / by the vehicle, but compared to GPS speed (see below) it's only off by 0.5% with actual speed being higher.
OEM Wheels have roughly 1% difference (again, actual speed is higher)
22's
Ford F-150 Lightning Efficiency at 70 vs. 75 vs. 80 on highway? 1685897200140
Lariat 20 OEM
Ford F-150 Lightning Efficiency at 70 vs. 75 vs. 80 on highway? 1685897629272
Jseis
Washington
Where I live there’s no way you can average 60 much less 70 or higher. At 58 the state bulls won’t pull you over, maybe flash their lights though. Besides there are way too many elk, deer, bear, hunters making them move, plus downed tree limbs, etc for any sane driver to want to haul ass. And that’s nice weather.
I just came east from Montana on I-90 with a stiff easterly headwind. Lucky to average 1.6-1.7 at 64-65.
dajohn3
2023 Ford Lightning
I have a 2023 ford lightning that I bought new in Jan 2024 and have made 3 trips to my ranch that is 525 miles from my main home one way. At 80 mph you won't see 1.8 or 2 per KW but you will see 1.2 and 1.4 respectfully. Now Ford, has fudged the numbers using the EPA as the bad guys and accepts no responsibility for you not achieving a good range. How Ford fools you is by redirecting you to a charging station when the vehicle is close to not being able to make it to the charging station you chose for your next recharge. I experienced this while driving from Ft Stockton, TX to Van Horn, TX every time and the NAV display kept on redirecting me to Pecos, TX. Also, I did find that it was less expensive to charge my truck with my 8,75 KW inverter generator than charging at electrify America at .56 per KWH at 7.2 hours of run time on 4.2 gallons of gas because you don't have to search or drive out of your way to find a charging station. I have even had Electrify America say that they can put 133 KW in a 98 KW battery when their charging station wasn't working properly. The EPA mileage is only relevant while driving 50 to 55 mph and then you may come close to getting the 320 for extended and 240 for the standard range batteries. But there is no guarantee! I have put my truck into the shop 2 times for not achieving the expected mileage and I hope with my next trip to my ranch that I will have better results than 1.2 and 1.4 miles per KWH. Don't get me wrong, I do like my Ford Lightning because it is comfortable and looks good but the range is not what Ford has been putting out. The Lightning that I have, based on the 138 miles of range at 100 percent that I have achieved, wouldn't make it to a charging station along my route to my ranch while pulling a 7000 lb utility trailer. This fact means that the only size battery that should be in a Lightning XLT is the 131 KW battery and Ford owes everyone who has a 98 KW battery a refund for not being able to pull anything far enough to reach a charging station at an acceptable rate of speed when you have a truck with the XLT trim.
mr.Magoo
2022 Lariat ER, AMB
The EPA rating is a synthetic test cycle, I don't think it's Fords fault for reporting a standardized number in a standardized way.
"We understand this is the numbers we're required to report, but trust us, our vehicles are much worse than that"
Not sure marketing would let that statement through. ?
I'm also sure that if you follow the EPA cycle you'll get close to, or even get better range than the rating.
https://www.fueleconomy.gov/feg/fe_test_schedules.shtml
If you look at the highway, high speed, cycle, it's only 10min long and during that cycle they average 48mph and top speed if 80mph for about 15s, so yeah, hardly your 200miles @80mph non-stop cycle, but again, that's not Fords fault.
The 320mile range is an average between 55% city where the lightning would get, say, 3 m/kW and 45% highway "high speed" which is 60-65mph at 2.2m/kW.
(3x.55)+(2.2x.45)=2.64
130kw x 2.64 = 343 miles of glorious range.
Could Ford have been more open with real range at continuous speeds vs. EPA cycles, sure, bad marketing probably, but sure.
Should consumers educate themselves more before they drop 50-100K (or any amount for that matter) on their first EV, absolutely!
Maxx
I am at 9K, and my total average has been 2.4-2.5 depending on proportion of winter to summer miles I have had on it. Almost exactly as Ford has advertised. However regardless of the details of his complaint, I agree with underlying cause of it. For EVs, both manufacturer and EPA should forget about the current cycle and just do what a lot of youtubers are already doing; A 70 mph loop and use that to publish a range. You see a lot less complaint from Porsche owners than you do from Tesla owners because the published range is closer to highway range. Once they match it, most of the complaints will go away.
MM in SouthTX
2025 Lariat PowerBoost with 7.2kW ProPower
The people that report far better mileage than you while traveling at 80 mph are driving on busy interstates. They are moving with traffic, thus drafting. The busier the interstate, the better the mpg. I-10 for you is like I-37 for me between CC and San Antonio. Sometimes a mile to the nearest car, and never in heavy traffic. I get 1.5 at 75 in those conditions. Less with a headwind.
Get on the list for the Dodge Ram Rev with the 229 kWh battery. Available Q4 2024, so maybe 6 months from now. Maybe you could make it 200 miles with that trailer!
