Does your Lightning make this noise?
Replika
United States
MR. PLOW - ER Lariat
Here is a recording.
The sound is present whenever the truck is on. Seems to come from under the steering wheel. I can hear it while driving too.
Does every truck make this noise?
Txxthie
Robert
CT
2022 TM3 RWD LFP
My Lightning makes more “electrical sounds” when parked than I am accustomed to hearing with previous EVs. Sounds similar to your recording but it’s hard to tell. I tried turning off pro power to see if that’s causing it and it doesn’t help. Could this be the inverter making the noise?
Replika
United States
It does seem like it's coming in through the firewall. There is a similar noise from the wheel well area of both ends while charging.
Blochead21
PA
Black 22 XLT 311pkg
Mine sounds like this. I would say it’s normal.
Eastbaylightning
Antz Tony
Walnut Creek, California
F150 Lightning Pro
It's definitely louder than other EVs.
Mine sounds like this and I can hear it from the cabin inside.
I notice the loudest comes from the front passenger wheel well, when in R N D.
Is it normal???
HVAC blower motor?
Try adjusting the blower speed or turn off completely to confirm or eliminate it as a suspect.
Eastbaylightning
Antz Tony
F150 Lightning Pro
HVAC blower motor?
Definitely not an HVAC blower, because it was completely off.
What about OP's experience?, he said, when ON, while driving and while charging (HVAC would be off on last use case), but unknown by statements in post 1
lightspeed
2023 Lightning Lariat ER
Can't really tell how loud it is from the recording, but there is usually a pump type sound that comes from that area. Presumably it's the coolant pump. It's louder on the outside (but not objectionable).
Replika
United States
I tried HVAC off, A/C off, blower speeds, and screens in calm mode. The sound is present whenever the truck is in accessory or drive mode.
Could be a muted sound coming from the circulation pump(s) and drive train chiller compressor, are you in a warm climate?
mattskr
Matt
Austin, Texas
23 Lightning Platinum, 25 Armada, 26 Wrangler JLU
Is it normal???
THIS particular noise when in RND is the pedestrian alert system. Emits a god-awful noise from a speaker behind the bumper.
Replika
United States
I'm in a warm climate. It also starts right when the truck turns on. Not sure if that rules out the battery cooling system.
It seems like it should be possible to sound proof these high frequencies.
Replika
United States
Isn't that pedestrian noisemaker more of a low pitched drone? The posted recording is heard even in park, any time the truck is turned on.
VTbuckeye
Vermont
Mine makes a similar sound. Often when pro-power is on. Sometimes when charging, often when driving, but not all the time. It reminds me of the buzz from the ballast on a fluorescent light.
