dippinMike
Torrance, CA
2022 F150 Lightning Lariat
I got my setup ordered, here’s what I went with:
  • 2.3” leveling kit from Stage3Motorsports (thanks to you for the recommendation)
  • Anthem Off-Road Rogue 17x8.5 +0mm offset wheels
  • Nitto Recon Grapplers LT285/75R17 Tires
this is going on my 2022 F150 Lightning Lariat with Max Tow Package
Ajjra
New York
F-150 Lightning Lariat
How is the ride quality on a 75 sidewall compared with stock? Is it more plush?
AZT9
AZT9
Peoria, AZ
Can’t wait to see the final photos! ??
AZT9
AZT9
Peoria, AZ
Depends. Generally yes for sure! That’s with the factory tire pressures
Typoman
Larry
Willcox, Arizona
22 lightning
I’m assuming your mean 22” wheels? For me it’s simply preference. I prefer more tire than wheel for both looks and functionality. I found that tire prices varied a lot depending on brand obviously but also the popularity of the tire size. More popular sizes are made en mass whereas less used sizes tend to cost more due to economies of scale is my guess
I remember the lightning platinum with 22-in wheels saying that it gave best mileage.
dippinMike
Torrance, CA
for the install of the leveling kit, what instructions did you follow? Mine came in a box with no instructions.
AZT9
AZT9
Peoria, AZ
DM me when ya get a chance. Got some tips that will help
toby_d
Toby
Longmont CO
2022 F-150 Lightning 510A, 2015 Ram 1500 EcoDiesel
Could you drop them in here too? I'm looking for all the help I can get. I did note that Stage 3 suggests swapping struts from side to side in the video's comments which seems handy.
AZT9
AZT9
Peoria, AZ
Biggest thing I did to make install easy was not to mess
With the upper control arms. I removed the lower control arms AFTER MARKING THE LOCATION OF THE LOWER CONTROL ARM BOLTS. Then knocked out the tie rod ends to free up some space to wiggle out the suspension components. It was pretty easy to ease them out and back in. Note* the install of the. Stage 3 spacer will result in the coils to be rotated 180* which is by design I was told by the folks at stage 3. installing the lower control arm bolts to the marked location resulted in almost perfect alignment. Almost but a realignment is highly recommended.
toby_d
Toby
Longmont CO
How about the cornering? Not "wobbly", or at least not too much more than normal?
There is a noticeable difference on any vehicle dropping down to 17" rims from 20 or 22. Softer ride but less stability. Economy also suffers.
toby_d
Toby
Longmont CO
I wish there was a try before I buy option available to me. I like the idea of 17s, and there's some tasty Method and Brink wheels that fit, but I am not up for (much) sloppier handling.
I can get the tire I want (275/65R20) just sticking with 20s and it'll be 'enough' sidewall for what I do. Might just have to go that route despite 17s looking fantastic.
